    Load Sketchup file from URL or Specific Diretory
    3 Posts 3 Posters 397 Views 3 Watching
    • V Offline
      vhiguita
      I am implementing a ruby code that loads me a sketchup file(skp), this is my code:
      point = Geom::Point3d.new 10,20,30
      transform = Geom::Transformation.new point
      model = Sketchup.active_model
      entities = model.active_entities
      path = Sketchup.find_support_file "chimney.skp",
      "C:/Users/usuario/Downloads/pluginsketchUp/Sketchup/org.dworks.suide_1.0.0/exe/"
      definitions = model.definitions
      componentdefinition = definitions.load path
      instance = entities.add_instance componentdefinition, transform
      if (instance)
      UI.messagebox instance
      else
      UI.messagebox "Failure"
      How could I do, the file loads of a different path to "Components/Components Sampler/" or maybe of a specific url?.
      Thanks in advance.
      • chrisglasierC Offline
        chrisglasier
        @vhiguita said:
        point = Geom;;Point3d.new 10,20,30
        >  transform = Geom;;Transformation.new point
        >    "C;/Users/usuario/Downloads/pluginsketchUp/Sketchup/org.dworks.suide_1.0.0/exe/"
        >  if (instance)
        >  else
        >  end
        Thanks in advance.
        See this topic for similar idea.
        (Suggest you use code block as above in your posts.)
        With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
          Just set the path as a string
          path = "C:/Users/Usuario/then_any/valid_path/to a/Folder/MyLovelyPony.skp"
          If you use / as the file separator the path can be inside '' or "".
          But if it's \ then use '' ... OR escape the \ as \ inside ""...
          Loading from a file-path or from a url are handled different as set out in the API docs...
          Note you can use File methods to find the model's folder or a file's basename or filetype...
          model_path=File.dirname(model.path) model_name=File.basename(model.path, ".*") model_ext=File.extname(model.path)
          You can also make new file-paths using
          output=File.join(model_path, "MyOutputFile.txt")
          For example this would make a txt file with the model, into which you could write some data...
