    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 561.4k Views 102 Watching
    • fredo6F Offline
      fredo6
      @tomaszdrgas said:
      I guess it was a deliberate choice but still will mention it.. Unlike native sKetchup paint tool ThruPaint treats faces separated by a "hidden" lines as one surface. So if I will cut a face on 3 and then hide cutting lines sKetchup would paint it in 3 clicks and ThruPaint in just one..
      It is not big bother but it is a different behaviour and after using thruPaint few years still sometimes (today) makes me confiused..
      Is there an option somewhere in the settings to change it.. deeply hidden..
      Tomasz
      In the button palette, you have several options for selecting faces, among which "single Face"
      Fredo
      • pbacotP Offline
        Tomasz
        There are options right on the toolbar for different treatment of faces. First thing I check when I use the tool. It's different because it's better than the SU tool.
          Clochard Deluxe
          Hi Fredo,
          I'm really happy with your work on so many great extensions and i'm using them all the time πŸ˜„ However i keep running into a weird issue with thrupaint i just cannot explain.. I tried to make a clear example but am not sure if it's clear enough..
          When i apply a simple texture from the standard material libary it gets applied properly but when i try to do the same with some bigger phototextured ones it keeps on applying it in a strange skewed way..
          the face i apply it to is okay but the one perpendicular to it gets skewed.. I tripplechecked my axis and everything is on axis as far as i can tell.
          Do you or has anybody else got an idea of whats going wrong? I tried all kinds of things but seem to overlook the problem wich is quite frustrating πŸ˜‰
          thanks in advance!!
          • fredo6F Offline
            fredo6
            I think the best would be that you post the model so that I can have a look.
            Fredo
              Clochard Deluxe
              I made an example wich has the same problem. there always seem to be some sides off..
              example.skp
              • fredo6F Offline
                fredo6
                Here are some remarks
                1. make sure you are in NATURAL mode
                2. For the long faces, use Click and Drag to paint the 4 faces in continuity. You can interrupt the painting to orbit. Then, click on a face already painted and drag to the next face.
                3. For the short faces, just click on each face. As you can imagine, you cannot ensure continuity of surface for a cube-like shape.
                ThruPaint - Clochard de Luxe - example.skp
                  Clochard Deluxe
                  Thanks Fredo, you're the best!
                    Ahmed0007
                    Any update is expected soon?
                    please reply?
                    • fredo6F Offline
                      fredo6
                      Are you expecting anything?
                        Ahmed0007
                        i'm creator of TutorialsUp (youtube channel)
                        and i'm going to make a tutorial on it.
                        and if any major update is expected soon please let me know i will wait for it.
                        Thanks.
                        • fredo6F Offline
                          fredo6
                          Thanks.
                          No update planned for the time being.
                          And, by the way, congratulation for your tutorials, which are very well done and instructive.
                          Fredo
                            Does any difference between the 2 buttons Rotation of the Gizmo ?
                            Here i take the red one...
                            Result will be the same if i take the green one ?
                            https://i.postimg.cc/QM3mh45c/GIF-2-rotate.gif
                            • fredo6F Offline
                              fredo6
                              The buttons have the same role.
                                Thanks for the info! 😎
                                • pbacotP Offline
                                  Can someone demonstrate the proper way to paint cube with perspective or quad painting on it? I thought this was working before. Now I cannot do it. Sometimes if I remove two faces, paint the remainder with the quad setting and add the faces back it works.
                                  • fredo6F Offline
                                    fredo6
                                    A cube cannot be painted in Quad mesh, as this is not a quad mesh. At least one of the face will not be in continuity, unless your texture is perfectly symmetrical in U and V. And if so, use the Natural mode.
                                    • pbacotP Offline
                                      Thanks!
                                        chaosaic
                                        hello . I'm kind of beginner of sketchup and your wonderful plug-in.
                                        now I have some serious problem using Thrupaint.
                                        The main problem is super slow whenever I paint UV map or adjust UV map(visual editor or simply use arrow key)
                                        in every kind of furface(probably plain,non curve surface is the only kind that's still work normally)
                                        288 faces sphere is slow(around 30sec),74 faces cylindrical is slow.
                                        even 6x6 grid rectangle from sandbox tool takes about 20sec to apply UV map.
                                        it's just frozen there about 30sec or several minute.
                                        I have tried : turned off vray extension , turned off fast feedback in OpenGL,
                                        open ruby console before using Thrupaint(no error) or not using other software beside sketchup.
                                        still not working.
                                        the only way I find work better is to delete all other model in the file,just keep the one I want to paint. (but i have keep other model out of my sight,would that be a problem?)
                                        I'm using : sketchup 2018pro
                                        intel i7-8700 CPU
                                        NVIDIA geforce gtx 1060(driver is up to date)
                                        libfredo6 8.8a
                                        fredo6 tools 3.3c
                                        it has great ability to paint UV map.but i have no idea why it seems so unusable in my situation.
                                        please help if you have some time.
                                        • fredo6F Offline
                                          fredo6
                                          @chaosaic,
                                          Difficult to tell what is the problem.
                                          Could you indicate which UV mode you use (Natural, Projection, QuadMesh) and if you have a problem of performance in all modes.
                                          Also, what kind of texture do you use? Is it a heavy image?
                                            chaosaic
                                            @fredo6 said:
                                            @chaosaic,
                                            I have tested natural,quadmesh,projected in simple 146 faces cylindrical(24*6 + 2).
                                            all three mode take over than 20sec to put on UV map.
                                            and the visual mode is lag to hell.
                                            Using the default map in "sketchuv mapping tools"(rainbow-like checker)
                                            which is like 512x512 pixel?
                                            I have also try my own texture(1024x1024). still lag.
                                            If I delete most of other high poly model in the file. still need about 15sec.
                                            And if I change selection face to visible face,it will down to 5~10sec.
                                            (but sketchuv mapping tools and native paint bucket is instant operation.)
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
