    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 625.0k Views 102 Watching
    • fredo6F
      I think the best would be that you post the model so that I can have a look.
      • C
        Clochard Deluxe
        I made an example wich has the same problem. there always seem to be some sides off..
        example.skp
        • fredo6F
          Here are some remarks
          1. make sure you are in NATURAL mode
          2. For the long faces, use Click and Drag to paint the 4 faces in continuity. You can interrupt the painting to orbit. Then, click on a face already painted and drag to the next face.
          3. For the short faces, just click on each face. As you can imagine, you cannot ensure continuity of surface for a cube-like shape.
          ThruPaint - Clochard de Luxe - example.skp
          • C
            Clochard Deluxe
            Thanks Fredo, you're the best!
              Ahmed0007
              Any update is expected soon?
              please reply?
              • fredo6F
                Are you expecting anything?
                  Ahmed0007
                  i'm creator of TutorialsUp (youtube channel)
                  and i'm going to make a tutorial on it.
                  and if any major update is expected soon please let me know i will wait for it.
                  Thanks.
                  • fredo6F
                    Thanks.
                    No update planned for the time being.
                    And, by the way, congratulation for your tutorials, which are very well done and instructive.
                      Does any difference between the 2 buttons Rotation of the Gizmo ?
                      Here i take the red one...
                      Result will be the same if i take the green one ?
                      https://i.postimg.cc/QM3mh45c/GIF-2-rotate.gif
                      • fredo6F
                        The buttons have the same role.
                          Thanks for the info! 😎
                          • pbacotP
                            Can someone demonstrate the proper way to paint cube with perspective or quad painting on it? I thought this was working before. Now I cannot do it. Sometimes if I remove two faces, paint the remainder with the quad setting and add the faces back it works.
                            • fredo6F
                              A cube cannot be painted in Quad mesh, as this is not a quad mesh. At least one of the face will not be in continuity, unless your texture is perfectly symmetrical in U and V. And if so, use the Natural mode.
                              • pbacotP
                                • C
                                  chaosaic
                                  hello . I'm kind of beginner of sketchup and your wonderful plug-in.
                                  now I have some serious problem using Thrupaint.
                                  The main problem is super slow whenever I paint UV map or adjust UV map(visual editor or simply use arrow key)
                                  in every kind of furface(probably plain,non curve surface is the only kind that's still work normally)
                                  288 faces sphere is slow(around 30sec),74 faces cylindrical is slow.
                                  even 6x6 grid rectangle from sandbox tool takes about 20sec to apply UV map.
                                  it's just frozen there about 30sec or several minute.
                                  I have tried : turned off vray extension , turned off fast feedback in OpenGL,
                                  open ruby console before using Thrupaint(no error) or not using other software beside sketchup.
                                  still not working.
                                  the only way I find work better is to delete all other model in the file,just keep the one I want to paint. (but i have keep other model out of my sight,would that be a problem?)
                                  I'm using : sketchup 2018pro
                                  intel i7-8700 CPU
                                  NVIDIA geforce gtx 1060(driver is up to date)
                                  libfredo6 8.8a
                                  fredo6 tools 3.3c
                                  it has great ability to paint UV map.but i have no idea why it seems so unusable in my situation.
                                  please help if you have some time.
                                  • fredo6F
                                    @chaosaic,
                                    Difficult to tell what is the problem.
                                    Could you indicate which UV mode you use (Natural, Projection, QuadMesh) and if you have a problem of performance in all modes.
                                    Also, what kind of texture do you use? Is it a heavy image?
                                    • C
                                      chaosaic
                                      @fredo6 said:
                                      @chaosaic,
                                      I have tested natural,quadmesh,projected in simple 146 faces cylindrical(24*6 + 2).
                                      all three mode take over than 20sec to put on UV map.
                                      and the visual mode is lag to hell.
                                      Using the default map in "sketchuv mapping tools"(rainbow-like checker)
                                      which is like 512x512 pixel?
                                      I have also try my own texture(1024x1024). still lag.
                                      If I delete most of other high poly model in the file. still need about 15sec.
                                      And if I change selection face to visible face,it will down to 5~10sec.
                                      (but sketchuv mapping tools and native paint bucket is instant operation.)
                                      • fredo6F
                                        Maybe you can PM me the model so that I see if this is related to ThruPaint or to your machine configuration.
                                          Ahmed0007
                                          hi fredo6
                                          i'm making a tutorial about your this plugin but i think i found bug.
                                          it's not painting Dimensions in sketchup 2018-19
                                          what is the solution.
                                          Video
                                          Help.skp
                                          • fredo6F
                                            @ahmed0007 said:
                                            hi fredo6
                                            It's just a missing feature. Not sure if there is a value in this (versus using the native Paint tool).
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
