    Select component with ruby?
    8 Posts 5 Posters 1.3k Views 5 Watching
    • jeff hammondJ Offline
      jeff hammond
      what's the code for selecting a component by name?
      (or is there one?)
      ie- what exactly would I type into the console to select a component named "board"..
      (and I realize it may require more than one line.. in the past, I've typed multiple lines in a text editor then copy/pasted into the console.. and it works ok.. is there a better way to do that if need be?)
      gracias!
      dotdotdot
        Sketchup.active_model.selection.add( Sketchup.active_model.definitions['board'].instances )
        Note that this selects all instances in model - which might not be in the current context. Selections across context can make SketchUp behave oddly. Ye have been warned!
          jeff hammond
          sweet.. thanks!
          so far so good..
          dotdotdot
            driven
            gracias!
            hi Jeff,
            did you know you can input multi-line scripts into 'Ruby Console' by using Alt/Return at the end of each typed line and then Return [on it's own] to enter/use it.
            Also once somethings been entered you can re-use those same lines by toggling the up/down arrows to go back to a previously entered snip then hit return...
            john
              jeff hammond
              john
              tip 1 -- thank you… that's good to know.. how about a way to type a long line with some sort of character in it indicating it's a new line..
              something®like®this =
              something
              like
              this
              tip 2
              awesome. that's a good one too!
              dotdotdot
                Only on OSX. Not on Windows. 😞
                This works on both platforms, but I think OSX is a little bit smarter. If you execute a command multiple times OSX it will merge them together onto one item in the history stack.
                  Of course adding a ' ;' into a line works as if it were a 'newline', needed in some code...
                  So puts 123;puts 456;puts 789 in the one line is like typing the commands on three separate lines in turn...
                  • Dan RathbunD Offline
                    Dan Rathbun
                    ruby will allow spanning lines with a \ (in some cases.)
                    I'm not here much anymore.
