    Styles with problems.
    13 Posts 4 Posters 1.3k Views 4 Watching
    • arqpadaoA Offline
      arqpadao
      Hi guys.
      I have not seen this question here on the forum.
      I have a problem, my styles are with this question mark.
      How do I fix this?
      Thanks.
      fernando padão
      arquiteto
      porto alegre - brasil
      http://arqpadao.blogspot.com
        Maybe there is not exist in the folder ?
        • arqpadaoA Offline
          arqpadao
          Hi Pilou.
          The worst is that there is a folder and the items are all there.
          fernando padão
          arquiteto
            Does rebooting the computer change anything?
            • arqpadaoA Offline
              arqpadao
              Hi Dave
              Have deleted the file from the styles and put another new Sketchup and not solved.
              Have not figured out what caused it, and still have not found a solution.
              I'm avoiding to reinstall SketchUp.
              fernando padão
              arquiteto
                Do you get the question mark on every style?
                Just for fun and because I'm not certain what to do next, would you select a style and hit the Edit tab? Then click on the wireframe cube below the select tab to show the Edge settings. I might be grasping at straws but I wonder if there's a setting there that isn't working.
                • arqpadaoA Offline
                  arqpadao
                  The worst part is that everything is OK.
                  fernando padão
                  arquiteto
                    Just show me the screen shot I asked for.
                    • arqpadaoA Offline
                      arqpadao
                      Dave
                      Follows the requested image.
                      fernando padão
                      arquiteto
                        Does anything happen when you click on the thumbnail for the style?
                        • arqpadaoA Offline
                          arqpadao
                          No, it's normal.
                          fernando padão
                          arquiteto
                          • jeff hammondJ Offline
                            jeff hammond
                            here's an older post on this with a sort of solution in there..
                            http://forums.sketchucation.com/viewtopic.php?f=15&t=10278
                            dotdotdot
                            • arqpadaoA Offline
                              arqpadao
                              Hi Jeff,
                              The process of deleting the folder and put a new'd done, and to no avail.
                              I went to the radical process, reinstalled SU.
                              Ok now this.
                              Thank you all.
                              fernando padão
                              arquiteto
