    Joint Push Pull Issue (Been using this plugin for a while)
    4 Posts 4 Posters 323 Views 4 Watching
      jayjay402
      New here, so sorry if I've posted this in the wrong place.
      I've been using sketchup and the joint push pull plugin for a while now, and only ever had small issues, which i've been able to fix myself by reversing certain faces, or scaling the model first or something, etc.
      I'm trying to add thickness to a new form i've made, but it seems to get to a various percentage anywhere from 1 to 85% and then crash and 🀒
      Its a fairly basic model, as clean as I can get it as far as I can tell. There's no stray lines or intersecting faces etc. I've also tried doing it as a closed shape, and not closed (bottom face deleted)
      Im using Sketchup 8.0.4811
      on Windows 7 64bit
      Pentium Dual Core Processor
      4GB ram
      Nvidia GeForce GT120M Cuda 1GB
      All I want to do is to add 0.5m thickness to the form (attatched below). I need the thickness to be added to the inside of it.
      Thanks for any help. πŸ˜„
      Site & Model 1-1 05 06 THICKNESS ONLY 02.skp
      • sdmitchS Offline
        sdmitch
        Crashes on me also. Looks like a job for Fredo.
        http://sdmitch.blogspot.com/
        • gillesG Offline
          gilles
          if you clean up coplanar faces it works fine.
            If the model is first 'cleaned' - i.e. deleting coplanar edges/faces etc - JPP works just fine ... πŸ˜•
