    Need help with texture in sketchup. Texture layers?
    4 Posts 3 Posters 446 Views 3 Watching
    • B
      Blah11
      Hello, there seems to be a problem with my textures in sketchup, I am using deep exploration to make the texture maps and once I export to sketchup I seem to loose the 2nd texture map. As you can see I decaled an icon on this green surface but when I export to sketchup I loose the icon. I'm guessing sketchup doesn't handle texture layers? Is there a way I can apply a texture in sketchup on top of another, the UV map is already set all I need is to apply it.
      http://efvzo.weebly.com/uploads/1/1/6/2/11621007/3237299.png
      • TIGT
        Can't be done...
        Merge the images before making the texture with the one...
        • B
          Blah11
          Lets hope that will be a feature in sketchup 9, seems something major they should have implemented.
          • GaieusG
            I doubt it it'll be a feature soon.
