    Animation with Maxwell
    extensions
    9 Posts 4 Posters 2.2k Views 4 Watching
    • V
      valerostudio
      Is there really no way to export an animation with Maxwell?
      • jason_marantoJ
        jason_maranto
        Not a native SketchUp "animation" directly, it lacks most of the features of a true animation... however if you are using one the other Ruby plugins that creates scenes for each frame, then you can use this script to render a animation framestack from a single MXS file:
        http://www.maxwellrender.com/forum/viewtopic.php?p=339519#p339519
        However be aware that since this is not a "true" animation there is no motion blur effect(since each scene/camera does not "know" where it is in time).
        True animation for SketchUp was one of the major feature requests for v9 and I suspect that there will some real animation capabilities added... which would then enable the Maxwell plugin to render true animations as well.
        Best,
        Jason.
        • soloS
          solo
          Just curious, why in the world would you even consider animation in Maxwell? I mean it is solely an unbiased engine, so every single frame will take a long time to resolve and you would need to estimate the passes per frame. Would you be using a render farm for this?
          http://www.solos-art.com
          • andybotA
            andybot
            you can't be that annoyed at vfsu can you? πŸ˜‰
            • V
              valerostudio
              Actually, I like the grainy effect that it produces. I would really only be rendering each frame to SL of 6-8. I would never use it to get clean renders, that would take years.
              • andybotA
                andybot
                I'll be curious how it turns out (if it works) Hope it's something you can post when it's done. As a thought - if you're looking for grainy, I like the quality of DMC instead if irrmap with vray.
                • V
                  valerostudio
                  This is a good point. DMC is much forgotten sometimes.
                  • andybotA
                    andybot
                    πŸ˜† certainly is the forgotten stepchild to irrmap. As far as I understand, it shows up with a new name in vray 2.0 = "brute force"...
                    • V
                      valerostudio
                      That is correct. I hear a lot of folks use it for interiors, if they have the time to let it cook. It does produce some nice grainy results. Perfect for what I am looking to do.
