Animation with Maxwell
Is there really no way to export an animation with Maxwell?
Not a native SketchUp "animation" directly, it lacks most of the features of a true animation... however if you are using one the other Ruby plugins that creates scenes for each frame, then you can use this script to render a animation framestack from a single MXS file:
http://www.maxwellrender.com/forum/viewtopic.php?p=339519#p339519
However be aware that since this is not a "true" animation there is no motion blur effect(since each scene/camera does not "know" where it is in time).
True animation for SketchUp was one of the major feature requests for v9 and I suspect that there will some real animation capabilities added... which would then enable the Maxwell plugin to render true animations as well.
Best,
Jason. -
Just curious, why in the world would you even consider animation in Maxwell? I mean it is solely an unbiased engine, so every single frame will take a long time to resolve and you would need to estimate the passes per frame. Would you be using a render farm for this?
you can't be that annoyed at vfsu can you?
Actually, I like the grainy effect that it produces. I would really only be rendering each frame to SL of 6-8. I would never use it to get clean renders, that would take years.
I'll be curious how it turns out (if it works) Hope it's something you can post when it's done. As a thought - if you're looking for grainy, I like the quality of DMC instead if irrmap with vray.
This is a good point. DMC is much forgotten sometimes.
certainly is the forgotten stepchild to irrmap. As far as I understand, it shows up with a new name in vray 2.0 = "brute force"... -
That is correct. I hear a lot of folks use it for interiors, if they have the time to let it cook. It does produce some nice grainy results. Perfect for what I am looking to do.
