    Best way to return a value from a tool ?
    6 Posts 4 Posters 371 Views 4 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      After several searches here and there, I'm searching for the most simpler and clever way to code a tool that will return a value after it ends.
      For instance: I've made a tool which measures the total distance as the user clicks points on his model.
      When he selects another tool, I want my code to get the 'distance' property (instance variable) of that tool)
      Thanks for your help,
      DB
        Make it a class, that's a Tool.
        As well as activate have deactivate(), which runs when the user selects another tool etc.
        If the total length is remembered as an @ you can use that in an exiting dialog...
        def deactivate(view)
            UI.messagebox("Total Length = #{@length}") if @length
            Sketchup;;set_status_text("")
            return nil
        This is a basic solution... Remember to [pre]format @length in appropriate units etc as needed...
        For pressing ESC etc could invoke 'onCancel()' similarly, BUT you'd probably not want to have the output then.
          Ensuring @length is a Length class will ensure SketchUp formats the length in the model's current unit. There is rarely any need to perform any unit formatting.
            Didier Bur
            Thanks guys,
            That was still the case (I don't know how to create a tool without making it a class πŸ˜† )
            I tested various solutions to retrieve the @distance property... except deactivate(), so thanks a lot TIG !
            DB
            • Dan RathbunD Offline
              Dan Rathbun
              Inside the Tool class use:
              attr_reader( :distance )
              so you have a getter method
              I'm not here much anymore.
                Didier Bur
                Thanks Dan,
                I still had an attr_accessor :distance in that class πŸ˜‰
                DB
