    Best way to return a value from a tool ?
    6 Posts 4 Posters 440 Views 4 Watching
    • Didier BurD
      Didier Bur
      Hi all,
      After several searches here and there, I'm searching for the most simpler and clever way to code a tool that will return a value after it ends.
      For instance: I've made a tool which measures the total distance as the user clicks points on his model.
      When he selects another tool, I want my code to get the 'distance' property (instance variable) of that tool)
      Thanks for your help,
      DB
        Make it a class, that's a Tool.
        As well as activate have deactivate(), which runs when the user selects another tool etc.
        If the total length is remembered as an @ you can use that in an exiting dialog...
        def deactivate(view)
            UI.messagebox("Total Length = #{@length}") if @length
            Sketchup;;set_status_text("")
            return nil
        This is a basic solution... Remember to [pre]format @length in appropriate units etc as needed...
        For pressing ESC etc could invoke 'onCancel()' similarly, BUT you'd probably not want to have the output then.
          Ensuring @length is a Length class will ensure SketchUp formats the length in the model's current unit. There is rarely any need to perform any unit formatting.
          • Didier BurD
            Didier Bur
            Thanks guys,
            That was still the case (I don't know how to create a tool without making it a class πŸ˜† )
            I tested various solutions to retrieve the @distance property... except deactivate(), so thanks a lot TIG !
            DB
            • Dan RathbunD
              Dan Rathbun
              Inside the Tool class use:
              attr_reader( :distance )
              so you have a getter method
              I'm not here much anymore.
              • Didier BurD
                Didier Bur
                Thanks Dan,
                I still had an attr_accessor :distance in that class πŸ˜‰
                DB
