    Cantilevered Table design question
    14 Posts 6 Posters 2.0k Views 6 Watching
      Jonavery16
      Hey Guys, I'm putting together a craft room for my wife and part of the design is an area for gift wrapping. I wanted to build the table out of 2 sheets of 1" or 3/4" plywood laminated together. The question becomes how much support would a table like that need. Im going to attach my model of the table itself it you want to have a look. I'm also going to attach the whole model of the room, so if you have any suggestions that would be awesome.
      Jon
      PS Sorry for the size of the model, I got it as small as I could. Thanks again
      Bench file
      Craft Room Zip.zip
        davidheim1
        Jonavery,
        You might be better off making a torsion box instead of laminating two heavy sheets of plywood. A grid of 1x2 lumber, with 1/4 inch masonite or plywood glued top and bottom makes an extremely rigid but lightweight structure. It would still need brackets supporting it from below (gravity usually wins, after all), but they probably would not need to extend the full width of the torsion box. Their exact size would depend on the width of the table you intend to make.
        You can make the grid by sawing half-lap joints in the 1x2s, or simply butt the pieces together and hold them with some glue and finish nails. I'd base the grid on a 6x6 inch spacing. Again, that depends on the size of table you want to make.
        Best,
        dh
          Jonavery16
          Excellent, thanks for the feedback.
          Not sure if it matters if the 6X6 spacing is on center or edge to edge, I drew it up as edge to edge, but easy enough to change. Definitely a lot more work to make it this way, but I want it to stay on the wall, soooo I guess that's a good trade off 😄 .
          Thanks again.
          Gift Wrapping Bench.skp
            For the torsion box to work well, turn the grid pieces up on edge and then put a skin on the bottom surface, too. What you're doing is building a structure much like an airplane wing with both a top and bottom skin.
              You could just buy a ready made cheap standard flush-door blank that'd be much the same size [2'6"x6'6"?].
              If it's hollow/semi-hollow cored and you want a more substantial top, then glue a sheet of ply/mdf over it.
              If it's not already lipped on all edges the pin/glue some hardwood lipping on the exposed edges...
              • mitcorbM Offline
                mitcorb
                I believe, after installing this table, you will eventually be adding legs to the free corners due to sagging and deflection, cyclical loading, wood shrinkage, and localized material fatigue at the fasteners.
                  Jonavery16
                  @Mitcorb- The table top has an overhang of 1" on the sides and 4" in the front. If anything wouldn't the sagging occur in the unsupported span in the middle? Which really gets back to the question at hand, how big of a span can I have without additional supports?
                  @DaveR Of course, that makes sense. I don't know what I was thinking. Thanks.
                  @TIG the problem for me with a hollow core door is the attachment points for the lower supports are going to be in the middle of the face of the door. I would need to find a way to attach the door without protruding through the top of the door panel.
                    A flush door, even hollow-cored, has solid wood as rails and stiles and mid-rail/blocking out...
                      Jonavery16
                      Modified the model to reflect suggestions
                        Jonavery16
                        I knew it had some solid wood for the door hardware, based on the image it looks as if the solid wood pieces at the top and bottom of the door are roughly the same dimension all the way around. I suppose it would depend on manufacturer but that would work.
                        • mitcorbM Offline
                          mitcorb
                          Ok, just don't let "Aunt Bertha and her Holstein Revue" dance around on it. Do yourself a favor and replace the section of gypsum wallboard on the studs with equal thickness of plywood to be covered by the wall mounting plate. Then use lag screws from hell to attach the assembly to the studs. Also, place an intermediate gusset like the end ones and use clip angles to secure these gussets at the wall plate.
                          There will be sag/deflection--it's just a matter of degree. How much can you put up with after the effort?
                            Jonavery16
                            My Aunts gonna be pissed she can't dance on this one...
                            Thanks for the suggestions re: mounting procedure.
                            This project is slowly becoming a big pain in the ❗ ❗ ❗
                            • pbacotP Offline
                              45 deg. Angle braces might work besides legs, but you need solid connection at the top to the wall, such as lag bolts. I've seen drafting tables built this way (that will fold down with a hinge). (that's how old I am--I've seen drafting tables.)
                              If you have a source or want to go to the trouble for a sleek look. Steel angles are used bolted to the sides of studs to provide hidden support to counters that are open below.
                              • mitcorbM Offline
                                mitcorb
                                Maybe something like this:
                                http://www.amazon.com/John-Sterling-BK-0103-22-300-Pound-Capacity/dp/B0009SUWEW/ref=sr_1_12?s=hardware&ie=UTF8&qid=1333217520&sr=1-12
                                I just think to be safe, use no less than three brackets like this for the length of the table. It would be preferable that the horizontal arm reach at least 1/2 the width of the table from wall to front edge. Those fasteners have to resist pullout from Aunt Bertha, or, perish the thought, Uncle Bubba.
