    I'VE ALMOST HAD IT WITH TRYING TO UNDERSTAND DC's!!!!
    41 Posts 17 Posters 6.3k Views 17 Watching
      ArCAD-UK
      Well this turned into a surprising thread. I hadn't expected so many experienced users to be having issues with DCs. I guess someone needs to grab hold of this aspect of SU and give it a real good shake to give us a more useable format.
      I did have another play yesterday to create an inclined beam and realised that DCs are really lacking some basic shape modelling commands such as add and subtract, but with SU's solid modelling this must now be a realistic prospect?
      • gullfoG Offline
        gullfo
        yeah, naming your parts and using materials (i use colors named as needed "lumber_stud", "machine_bolt" etc then replace if used for rendering later) is key to making the reporting work well. then i import to excel and run some macros to remove extraneous values and summarize (DSUM DCOUNT etc) to create the materials list. it would be nice to have the reporting take families of groups and report directly though...
        it would be cool if DC had a "record macro" function. but some more functions (like % (mod)) would be nice plus parent's parent referencing (as well as inserting of Ruby code πŸ˜„)
        Glenn
        http://www.runnel.com
        • utilerU Offline
          utiler
          Let's hope..... πŸ‘
          Just Curious...
            ArCAD-UK
            Glenn, I'm no Exel wiz but could you achieve what you need with a pivot table?
            • gullfoG Offline
              gullfo
              I do use Excel currently but i'm thinking a built-in solution for SU would be nice
              Glenn
                Andrew Jones
                Hi All,
                Where would I find a list of functions that could be used in DCs? Or a guide to the maths being talked about here? I've built a door DC but had the problem of it resizing things I don't want changed when it adjusts, but it looks like there are ways to stop that happening. I'm patient enough to work out formulas (actually enjoy excel stuff), and I figure if i can get what I need done in a week of working on the DCs, it still beats forking out on another program (not that I can find one that I like, or that has libraries I can use anyway)
                I'm hoping Trimble add a decent 2d drafting component and object library tools that way there is nothing I need elsewhere. At the moment I'm only searching for another program as my first project done in Skp Pro 8 took way too long. the windows on the house took 2 hours alone. Don't talk to me about the gutters, I think I have geometry stuck under my nails still...then the engineer wants changes and the ceiling heights are going up, all that starts making it like digging sand with a tooth pick.
                But as shite as they seem to be, DCs may be the thing I need to get into... and having 'group and layer it' tattooed on the back of my eyelids.
                cheers
                Andy
                  ArCAD-UK
                  Andy - If you open the Window>Component Attributes dialog there is a tab at the top which when clicked will then give access to a list all the functions. Additionally you can go here...
                  Error 404 (Not Found)!!1
                  (support.google.com)
                  for a more detailed explanantion.
                  As I've mentioned previously I gave up on DC's. My solution is to build individual non-DC components which can be quickly edited to suit a specific project e.g. a window where you only need to carry out two stretches 1. to change the overall frame and 2. the casement.
                  Good luck with your endeavours. Let us know how you get on!
                    Jim
                    Here's a good starting page...
                      Andrew Jones
                      Thanks ArCAD / Jim,
                      I'll have a good go at them an see if I can't get something happening. If it's just a matter of maths skills, then it can't hurt to stretch the ol' brain a bit. Might keep alziemers at bay...
                      • david_hD Offline
                        david_h
                        If it were me, I would just take a daily dose of coconut oil and do the little extra modeling.
                        πŸ€“
                        • jeff hammondJ Offline
                          jeff hammond
                          πŸ€“
                          it's not so much math skills (depending on what you're trying to make) rather it's figuring out the syntax(?) in order to make the things work.. if you're ok with making spreadsheets then you'll be ok with creating DCs..
                          dunno.. making DCs can be kind of fun if you're nerdy like that..
                          πŸ€“
                          @andrew.. if you bump into any problems, make a thread showing where you need help.. i'm sure some people will be glad to assist
                          dotdotdot
                          • david_hD Offline
                            david_h
                            Well . . .anything to stave off the Alzheimer's. For me. . it's crossword puzzles.
                            πŸ˜„
                              jeff hammond
                              πŸ˜„
                              ha.. i'm into crosswords as well.. nytimes (i don't mess around with sunday though πŸ˜‰, usa today, and the onion's weekly xword..
                              dotdotdot
                              • utilerU Offline
                                utiler
                                Thanks Jeff, I have tried that before but didn't get far with a solution. I thought everyone was in the same boat as me or either thinking I wanted someone else to do my work. I'm sure the penny will drop at some point.
                                πŸ‘
                                Just Curious...
                                • soloS Offline
                                  solo
                                  DC's, a great way to waste a lot of time figuring out only to realise the original method of actually modeling it in the first place is ten times faster.
                                  http://www.solos-art.com
                                  • jason_marantoJ Offline
                                    jason_maranto
                                    I spent something like a month (making 4 hours of video training) teaching most of the ins and outs of DC's in my SketchUp Pro training series -- which got very little traction (almost non-existent)... I think both DC's and Layout are very cool things (and I thought I taught them very clearly) but the demand for that information seems to be so small as to not justify any future tutorials on the subjects.
                                    Don't get me wrong I think they need to be re-worked and I've made my fair share of suggestions about them (and Layout)-- but they are much more useful than they are given credit for...
                                    I'd rather spend my time teaching things that people actually want to learn -- I make these things to get paid, but I also really want the information to be used... it's kind of like that old saw about "if a tree falls in the forest and nobody is around to hear it, does it still make a sound?".
                                    If nobody watches these things then I'm just some guy who spends alot of time talking to myself.
                                    Best,
                                    Jason.
                                      jason_maranto
                                      If all you are doing is modeling with DC's then maybe I could agree with that sentiment -- although that ignores the fact that DC's can be very powerful for adding randomization to your models that would be very time consuming to actually model.
                                      Really DC's are only minorly about modeling at all -- their strengths are really in areas that have very little to do with modeling... to understand DC's it is really helpful to think like a website designer, where you are not so worried about modeling per se but how the end user is going to interact with the model.
                                      If your goal is to make DC's for your own use then it's probably not worthwhile.
                                      Best,
                                      Jason.
                                      • utilerU Offline
                                        utiler
                                        A typical example of 'when to DC V when not to DC' are stairs. I know there are some guys who have gone to extraordinary lengths to create a Stair DC but I don't see why building a stair can not be done with a plugin.
                                        We know the total run and what local bylaws allow so what I do is input my perimeters [sdmitch's stair plugin is pretty neat! http://forums.sketchucation.com/viewtopic.php?f=323&t=39706&hilit=stair]
                                        I check my clearances and if I don't like it I delete it and run the plugin in again..... It's really not that difficult!
                                        Just Curious...
                                          That maybe true for your trade (where you mainly model individual, custom stuff all the time) and is definitelytrue for mine but imagine a kitchen cabinet maker who (say) generally works from a dozen of door styles, the same wood board thickness all the time and such. If they spend a week or two to model their variations, they can sit back and make a custom kitchen design with a couple of clicks next time a customer comes. It may even look "impressive" for the client if they do it in front of them.
                                          DC's can also be useful for manufacturers of (say) windows or doors. In this case, some (lazier) architects can easily place those things into the model. Just like those "finish" manufacturers (think of stone, brick, roof tile etc) who care to make nice textures of their products for arch-viz. Many will use them gladly (in the lack of other materials).
                                            sketchdata
                                            I agree that the Dynamic Components aren't perfect, but they are a great addition for the cabinet mfg. Most cabinet mfg don't want Designers creating a bunch of "custom" cabinets. Using DCs the Designers have some pretty powerful building blocks to create "semi-custom" cabinets, and then of course SketchUp allows them to create the crazy stuff to. Most of the software in the Woodworking industry is just good at drawing cabinets, but not so good at creating the custom stuff, DCs allows SketchUp to do a good job at both.
                                            • 2 / 3
