    I'VE ALMOST HAD IT WITH TRYING TO UNDERSTAND DC's!!!!
    Scheduled Pinned Locked Moved Dynamic Components
    41 Posts 17 Posters 4.9k Views 17 Watching
    • david_hD Offline
      david_h
      Ditto.
      • jeff hammondJ Offline
        Ditto.
        oh. I totally understand what you guys are saying and for the most part, I'm the same way.
        it's just that I happened to find a use for them in which it made sense for me to spend the time creating the DC.. so I was just adding my own experience.
        I do wish the sketchup team developed them much further beyond the initial release.
        a DC GUI of sorts would probably do wonders as far as getting more people to use them.
        the current implementation is far too codey(?) for most people. we generally want to SHOW the computer what to do instead of TELL it what to do.
        (the show vs tell is probably the wrong choice of words here.. replace them with whatever works better πŸ˜„ )
        • soloS Offline
          I agree, it should be easier, It feels like I need to learn a new program almost. I'd like presets with configurable options, drop windows maybe with options, easy building UI, etc.
          or even as you suggest something like a macro, where I can record the action.
            I was actually thinking something along the lines of grasshopper (maybe not as intense though πŸ˜‰ )
            maybe:
            [in DC design mode or whatever]
            select a face
            assign a push/pull modifier to the face.
            the modifier could then be controlled via a slider or numerical input etc
            or select a component
            assign a move modifier to it
            show the direction you like
            check yes/no for copymove
            etc
            itd be a lot more user friendly like that
              Hoppefully this possibility of programming don't exist in the free version! πŸ˜„
              Maybe in the V9, so we can help you! πŸ˜‰
              Try Scratch or Byob (Hyper Scratch) for your kids or you and DC will seem more easy! πŸ˜‰
              • KrisidiousK Offline
                Krisidious
                DC's are half the reason I bought Pro 7 and gave up very soon after the purchase. I figured I was just too dense to get it.
                By: Kristoff Rand
                • utilerU Offline
                  utiler
                  phew... now I feel much better that you guys are of the same opinion....
                  I like that idea about selection a face and applying a group of settings to come up with what's require: Goh's 1001bit tools does a similar thing and it works well for me.
                  Maybe I just drop the DC thing all together.
                  Just Curious...
                    Trogluddite
                    I concur with ArCAD's experience - the way DC's are deployed completely hampers their usefulness.
                    I have plenty of programming experience, so found the maths side not too bad and managed to create several DC's that I thought would be useful....
                    ....until I looked in my Components toolbox - "Part#1", "Part#2", "Part#3",..etc...
                    ...which I then rename as "Part Small", "Part Big", "Part Huge" etc. and then try to remember to drag the right one into the model so that I don't then end up with another new series of #1,#2,#3... (except that I will anyway if I alter any parameters "on site").
                    I think, at best, they can be used as a kind of templates for quick construction of regular "non-DC" components. But as has been pointed out already, SU is so fast to model with, that I may as well have just built "Part Small", "Part Big"... as separate components in the first place.
                    To be more useful, I would like to see something like...
                    • Only ever one definition (visible?) in the component toolbox.
                    • A new native component attribute "Suffix", visible in the Outliner - e.g. for a component called "Nut", we could add "M3","M4" etc. according to parameter values - purely as "aliases" to help us see what is what and for use in reports, but not changing the DC definition in any way.
                    • "Variants" itemised according to their parent definition and sorted by parameter values in reports. So I can quickly see that I have used 25 M3 Nuts, rather than having to check each "Nut#x" component individually to see see what parameters it has.
                    In principle, DC's have a lot of potential - but I doubt it can ever be realised unless the implementation is thoroughly overhauled.
                      ArCAD-UK
                      Well this turned into a surprising thread. I hadn't expected so many experienced users to be having issues with DCs. I guess someone needs to grab hold of this aspect of SU and give it a real good shake to give us a more useable format.
                      I did have another play yesterday to create an inclined beam and realised that DCs are really lacking some basic shape modelling commands such as add and subtract, but with SU's solid modelling this must now be a realistic prospect?
                      • gullfoG Offline
                        gullfo
                        yeah, naming your parts and using materials (i use colors named as needed "lumber_stud", "machine_bolt" etc then replace if used for rendering later) is key to making the reporting work well. then i import to excel and run some macros to remove extraneous values and summarize (DSUM DCOUNT etc) to create the materials list. it would be nice to have the reporting take families of groups and report directly though...
                        it would be cool if DC had a "record macro" function. but some more functions (like % (mod)) would be nice plus parent's parent referencing (as well as inserting of Ruby code πŸ˜„)
                        Glenn
                        http://www.runnel.com
                        • utilerU Offline
                          utiler
                          Let's hope..... πŸ‘
                          Just Curious...
                            ArCAD-UK
                            Glenn, I'm no Exel wiz but could you achieve what you need with a pivot table?
                            • gullfoG Offline
                              gullfo
                              I do use Excel currently but i'm thinking a built-in solution for SU would be nice
                              Glenn
                                Andrew Jones
                                Hi All,
                                Where would I find a list of functions that could be used in DCs? Or a guide to the maths being talked about here? I've built a door DC but had the problem of it resizing things I don't want changed when it adjusts, but it looks like there are ways to stop that happening. I'm patient enough to work out formulas (actually enjoy excel stuff), and I figure if i can get what I need done in a week of working on the DCs, it still beats forking out on another program (not that I can find one that I like, or that has libraries I can use anyway)
                                I'm hoping Trimble add a decent 2d drafting component and object library tools that way there is nothing I need elsewhere. At the moment I'm only searching for another program as my first project done in Skp Pro 8 took way too long. the windows on the house took 2 hours alone. Don't talk to me about the gutters, I think I have geometry stuck under my nails still...then the engineer wants changes and the ceiling heights are going up, all that starts making it like digging sand with a tooth pick.
                                But as shite as they seem to be, DCs may be the thing I need to get into... and having 'group and layer it' tattooed on the back of my eyelids.
                                cheers
                                Andy
                                  ArCAD-UK
                                  Andy - If you open the Window>Component Attributes dialog there is a tab at the top which when clicked will then give access to a list all the functions. Additionally you can go here...
                                  http://support.google.com/sketchup/bin/answer.py?hl=en&answer=108144
                                  for a more detailed explanantion.
                                  As I've mentioned previously I gave up on DC's. My solution is to build individual non-DC components which can be quickly edited to suit a specific project e.g. a window where you only need to carry out two stretches 1. to change the overall frame and 2. the casement.
                                  Good luck with your endeavours. Let us know how you get on!
                                    Jim
                                    Here's a good starting page...
                                    http://support.google.com/sketchup/bin/topic.py?hl=en&topic=22496
                                      Andrew Jones
                                      Thanks ArCAD / Jim,
                                      I'll have a good go at them an see if I can't get something happening. If it's just a matter of maths skills, then it can't hurt to stretch the ol' brain a bit. Might keep alziemers at bay...
                                      • david_hD Offline
                                        david_h
                                        If it were me, I would just take a daily dose of coconut oil and do the little extra modeling.
                                        πŸ€“
                                          πŸ€“
                                          it's not so much math skills (depending on what you're trying to make) rather it's figuring out the syntax(?) in order to make the things work.. if you're ok with making spreadsheets then you'll be ok with creating DCs..
                                          dunno.. making DCs can be kind of fun if you're nerdy like that..
                                          πŸ€“
                                          @andrew.. if you bump into any problems, make a thread showing where you need help.. i'm sure some people will be glad to assist
                                          • david_hD Offline
                                            david_h
                                            Well . . .anything to stave off the Alzheimer's. For me. . it's crossword puzzles.
                                            πŸ˜„
                                            • 2 / 3
