    E MAIL DRAWING
    5 Posts 5 Posters 320 Views 5 Watching
      JOEBLOW67
      i WOULD LIKE TO E MAIL A DRAWING I'VE MADE. I AM USING SU8 WITH WINDOWS XP
      • gillesG Offline
        gilles
        Where is the problem?
          Please explain yourself properly πŸ˜’
          For example do you mean "Drawing" [DWG?] or "Model" [SKP] ??
          Do you mean to 'attach' it to a post here on this forum, or to 'attach' it to an email that you want to send to someone else?
          If your email client won't allow direct SKP files attachments then first compress it as a ZIP file first.
          However, this forum allows many file formats to be attached directly [see just below the typing pane as you write the post for 'upload attachment...'] - DWG and SKP will attach without zipping. All others will attach when zipped...
          Incidentally... please don't type your posts in ALL CAPITAL LETTERS - it is harder to read, and to many it appears like 'shouting', and is regarded as 'bad-manners'...
          • dukejazzD Offline
            dukejazz
            Make it a attactment, don't enbed it or it will br block by the smart filters
              mics_54
              I'm going to assume Joe wishs to share a drawing with some one that cannot currently view it in either .skp or cad file format.
              Joe if that is the case blink your left eye twice. πŸ˜„
              seriously...most people can view jpg images which you can use by exporting the view of your model as a jpg
              or...you can use a "print to pdf" application if you are familiar. I use pdf995 there are others available.
