    How to select the reflections only on a scene with water?
    renderpluginsextensions
    2 Posts 2 Posters 242 Views 2 Watching
    • N Offline
      NorthShoreArchitect
      Hi, I would like to know how to select the reflection on the wate on the scene plus the architecture so I can add both to an image I already have of where this structure actually goes. Does anyone know how to select only the reflection in the water, I've tried the reflection channel but no success.
      • eidam655E Offline
        eidam655
        i assume you render with VRay - since Reflection channel didn't help, you could try Raw Reflection.
        but maybe an easier way would be to remove the color from the sea and leave it white - that way the bumps would stay but you would have no problems with selection.
        I'm using SketchUp 2017, V-Ray 3.4
