    Importing colors from Rhino
    extensions
    11 Posts 6 Posters 1.8k Views 6 Watching
    • M
      muscari
      Is there any method to import a mesh/polygone with it's colors from Rhino into Sketchup? So far I've only imported 3ds files for somplicity, but colors don't transfer.
      • soloS
        solo
        I do not use Rhino however there are a few things you can try...
        Create a folder for the imported mesh, save to folder, the materials should be saved there also, secondly in Rhino change name of materials to anything without symbols and 6 or less letters.
        http://www.solos-art.com
        • M
          muscari
          Hmm... I think the attached image should explain a bit more of what my actual problem is. As you can see, it's not only the colors that I want to keep, but the pattern as well.
          • jeff hammondJ
            jeff hammond
            export from rhino as OBJ
            use TIGs 'import OBJ with textures' plugin to get it into sketchup
            http://forums.sketchucation.com/viewtopic.php?t=20584
            dotdotdot
            • mitcorbM
              mitcorb
              Is that grasshopper window like Blender's "logical linking"(?) window? I don't know what it's really called.
              • M
                muscari
                @Jeff: Thanks for the link, will try it out 😄
                @mitcorb: no idea, have never used blender. And do you mean the Grasshopper window as a whole (plugin) or the image sampler component inside it?
                • mitcorbM
                  mitcorb
                  Hi, muscari:
                  I meant the group of boxes interconnected with the curvy lines. There is/was a window in Blender that showed the logical connections between various operations in a model. You could move these around, make new links between different boxes, etc. Since I never got past the curiosity stage with this, any moderately complex model viewed this way looked like total confusion to me, because only a database machine could have kept track of it in my opinion.
                    Just the "famous nodes' system" of all modern program of today 😄
                    After 10 boxes your headache can begin! 💚
                    • M
                      muscari
                      10!? Man, just getting one to work can make me lose my will sometimes...
                      • M
                        muscari
                        I've run into a bit of a problem, and it's that anytime Rhino tries to export this geometry as an .obj it freezes. Anybody know another way to import?
                        • S
                          sepo
                          That is certainly grasshopper plugin for Rhino. You should save the file as native.3dm first and than export it as.obj.
