    USMC X-1 Theseus - Going to the Moon....
    10 Posts 5 Posters 2.3k Views 5 Watching
    • K Offline
      Khai
      I give you the USMC X-1 Theseus
      Modeled in SU7... Rendered in PoserPro, untextured atm (just an IBL and Ambient Occlusion light setup used)
      [xxl-img:zkzvkgj7]http://farm8.staticflickr.com/7111/6851440102_7aa41c4f44_b.jpg[/xxl-img:zkzvkgj7]
      [xxl-img:zkzvkgj7]http://farm8.staticflickr.com/7231/6997564379_9e354a1181_b.jpg[/xxl-img:zkzvkgj7]
      [xxl-img:zkzvkgj7]http://farm8.staticflickr.com/7252/6997564651_2168a4ef99_b.jpg[/xxl-img:zkzvkgj7]
      Still have the Nose to work on...
      • Bryan KB Offline
        SWEET!
        • DanielD Offline
          Daniel
          Love the retro style. No view ports or hatch?
          My avatar is an anachronism.
          • K Offline
            Khai
            those I'll add once I've got the main modeling done.. planning to seperate out panels in the hull to allow me to put different hatches / viewports in as I like.
              liam887
              excellent, what method did you use for the panels in SU?
              VISIT MY ONLINE GALLERY
              • K Offline
                Khai
                the method I've been using is to select the faces I want to make the panels of, then use "tools on a surface" to inset a .5mm ring. (I then tidy the corners to make Quads) then I select the inner faces and smart push/pull .5mm to give me the panel. (I then inset again, but that's for Poser, to give a sharp edge. otherwise poser's inbuilt smoothing will cause problems)
                  liam887
                  Yes good work, I can see segmentation now I look deeper but still amazing work!
                  • K Offline
                    Khai
                    gonna be delayed on completing this..
                    first my 1TB Primary drive took a dump. thanks to a mate, I was able to save my main system / work partitions to a 500GB. (the rest I can save later when I more HD space..)
                    then my graphics card took a dump. the cooling fan's going On/off/on/off/on/off... so right now, I'm stuck with the onboard video.. (a 6150le whatever that is.....)
                    be a coupla weeks before I can afford a new GFX card...
                      Remember πŸ˜„
                      http://membres.multimania.fr/youpi98/haddock/lune.jpg
                      • Bryan KB Offline
                        Tin Tin!
