    Export Layers to AutoCad
    2 Posts 2 Posters 744 Views 2 Watching
    • E
      edarchitect
      Has anyone developed a method to export Sketchup layers, along with the 2D tab view to AutoCad? On Youtube, there is a method that uses colors of objects, but it is still time consuming and one must still redefine the layers in AutoCad. An application that would directly export the layer structure would be wonderful.
      • TIGT
        A Pro 3d Export to DXF/DWG will keep the layering as in the SKP.
        The CAD files layer-colors should match the SKP's layer-colors
        The Scene tabs should also come over as Paperspace layout tabs in the DWG...
