    Intersect selection problem !
    25 Posts 8 Posters 7.4k Views 8 Watching
    • ely862meE Offline
      ely862me
      Am I stupid ??!!
      I'm trying for about an hour now and it seems that there are higher laws that govern Sketchup which I'm simply not aware of !!!
      It all started with V8 . When intersecting geometry there were hidden lines that appeared of a sudden. Sometimes they can be deleted ,sometimes not .
      In the attached case I am trying to intersect some cylinders with a plane. After intersecting, a hidden line appears and not all the cylinders get intersected with the plane.
      Is this happening to you too , or it's on my side only?
      See attached !
      Thanks !
      Group_5 intersecting problem.skp
      Elisei (sketchupper)
      Come and See EliseiDesign
      • Rich O BrienR Online
        Constantly happens unfortunately 😞
        • ely862meE Offline
          ely862me
          If possible, how would you go around this BUG ? Perhaps I should draw all the circles manually ?
          Thanks for dropping by ! At least I know is not just me πŸ˜„ !
          Take care !
            I run cleanup after intersecting. That usually works.
            I was working on a model last night intersecting 5 3/8" holes on a flat surface. Next thing over 30 hidden lines placed arbitrarily on the face.
            Scaling up doesn't seem to help. If you delete lines faces disappear and if you heal that face then multiple faces are created.
              @ely862me said:
              Am I stupid ??!!
              Not necessarily but bear in mind that we do not promote normal people "Top SketchUcators". There must be some aberration in every one of them.
              (Mods and admins are even worse) πŸ˜’
              • Bob JamesB Offline
                Bob James
                This happens to me over and over. Also when I draw a rectangle or other shape on a flat, ungrouped surface it does not "cut" the surface. This happens frustratingly often. 🀒
                Either I've joined the "stupid" club or this is a bug.
                • ely862meE Offline
                  ely862me
                  A bug for sure !
                  Ain't bad considering ourselves stupid at times πŸ˜† .
                  Google hear us up ..we need this bug gone !
                  • mitcorbM Offline
                    mitcorb
                    Well, you're not stupid. You discovered an ambiguous condition that either the program under the hood or OpenGL couldn't fathom.
                    • jeff hammondJ Offline
                      jeff hammond
                      I only had a quick look at it (limited web/computer availability right now) but there are some problems in there befor the intersect command happens.
                      using the first row in your drawing (which I assume is your setup prior to intersecting) -- if you triple click the rectangle (selecting everything except the cylinders) and check the entity info, you'll see there are 8 entities selected when there should only be 5 (the plane and its four edges)
                      zooming in shows some other lines very close to the plane edges which I think have something to do with the hidden lines etc popping up.
                      triple click the rectangle (again, select everything except the cylinders) and delete.. draw a new rectangle withouth the three extra lines and run the intersect command one the plane/cylinder.. everything works out ok now and a triple click on the resulting intersection will select the plane and all the cylinders except for the one you have as a group (as expected)
                      (posted from a phone.. excuses apply where need be )
                      dotdotdot
                        jeff hammond
                        honestly, I've never had this happen on 'good' geometry.
                        there's something wrong with your plane and it's hard to tell because I'm not sure how you arrived at it. (ie- I'm pretty sure you didn't just draw a rectangle then some cylinders and tried to intersect them)
                        If you scale up 50x then do a Statistics--> Fix Problems.. you'll get:
                        The plane equation for CFace (8172) is not valid.
                        The plane equation for CFace (8182) is not valid.
                        like I said.. I'm not exactly sure what's wrong with the plane but-- there is something 'bad' about it
                        dotdotdot
                          I've seen this happen on perfectly normal geometry. In fact intersecting actually causes the errors in the first place. Using the Fix Problems does correct it but why is SketchUp creating problems in the first place?
                          I'll go locate that file.....
                            Here's a file to test. 4 holes with 64 entities each and a face with 13 entities.
                            Error_Sample_Jeff.skp
                              jeff hammond
                              what it think happens is along these lines...
                              sketchup (and probably all cad apps) have some sort of tolerance in which a plane will actually form... at minuscule amounts, a plane will form and it won't be 100% coplanar. trying to do subsequent operations on this 'imperfect' geometry will cause problems.
                              do this:
                              scale ely's rectangle up 5000x (and delete those 3 extra lines.. 2 of them are on the short end nearest the origin and one is on a long side)
                              select the line tool and start it on one of the rectangle's corners.. get it on the blue axis and lock it there with shift key...
                              now touch on the other 3 corners.. if it were a true plane, that vertical line your trying to draw should always be 0 units... in this case (after scaling up 5000x) you'll see that one of the corners is higher by ~1/8"...
                              at the smaller scale, the plane was allowed to form as it was inside sketchup's coplanar tolerance.. upon upscaling, you'll see that it's not actually 100% flat..
                              is this making sense to anyone? πŸ˜„
                              dotdotdot
                                Can you explain why in my example intersecting geometry with the model rather than the selection it affects geometry that doesn't actually intersect?
                                  jeff hammond
                                  [attachment=0:w1yrphdg]<!-- ia0 -->Error_Sample_Jeff.skp<!-- ia0 -->[/attachment:w1yrphdg]
                                  right.. same thing.
                                  scale the plane up 5000x then delete one of its edges.
                                  redraw the line and you'll see it no longer allows the face to form because at the larger scale, you've gone outside of tolerance and revealed that the plane's edges aren't actually coplanar.
                                  dotdotdot
                                    It's not the scaling I'm talking about here it's the fact that 'Intersect with Model' and 'Seletcion' can still cause issues.
                                    It's a bad example I know but it's something I run into every now and then.
                                      jeff hammond
                                      no.. I don't have a clue as to what sketchup has in place for trying to deal with invalid object.. but I do know that your plane, like ely's, is 'bad'
                                      dotdotdot
                                        jeff hammond
                                        well scaling only helps reveal the error.. and it shows sketchup's tolerances.
                                        I don't know what that tolerance actually is but basically, you can draw a square in sketchup which has one corner .000001" higher than the other three and a plane will still form.
                                        when you start intersecting and adding new planes (circles in these cases), the unflat plane sometimes needs to break itself up (the new hidden lines) so that all the edges still fall within tolerance and planes are able to form.
                                        I'd upload a sample file for demonstration purposes which would make this clearer but my web is via phone now.. I can download files then transfer to a computer but I don't have the proper app which allows me to do the opposit. sorry πŸ˜„
                                        dotdotdot
                                          jeff hammond
                                          expanding a bit on what I said last time..
                                          let's assume sketchup will let a plane form if one corner is 1" higher over a course of 1000'...
                                          when you try to intersect an object which is in the middle of that plane, you'll now have a corner which is 1" higher over 500'... this is now outside of tolerance so a hidden line needs to be formed.. essentially breaking the plane in as many pieces necessary to keep the 1" per 1000' allowable slope.
                                          (again.. that 1" per 1000' is purely for example.. I'm sure the actual tolerance is less than that)
                                          dotdotdot
                                            jeff hammond
                                            and I guess I'll add one other thing...
                                            I think you guys are stuck on 'intersecting is the problem'..
                                            well, let's forget about intersecting for now.. intersecting only reveals the problem but it's not causing it.
                                            focus only on the planes (in rich's and ely's drawings)... those are the real problems and both files are showing the same error) [and not surprisingly, react the same way when trying to use it for an intersecting plane ]
                                            take the drawings.. scale them up a thousand times or so.. delete one of the plane's edges then try to redraw that edge.. the plane will not reappear when it obviously should.. this is where you should be focusing you attention as this is Not an intersecting bug..
                                            good luck πŸ˜‰
                                            [edit] why is the wink emoticon showing up as the super happy guy?
                                            dotdotdot
                                            • 1 / 2
