    Animation Export - Cropped
    3 Posts 3 Posters 369 Views 3 Watching
    • C
      chaznsc
      Hello,
      Pretty new user here, but have a question regarding the export of Scenes. When I export my scenes, I do not get what I see on the screen. I realize we are dealing with a global sort of model, but is there a solution to export the scenes as I have them displayed, or rather, set some sort of limits for the scenes globally? Mine are cropping down 15% maybe.
      Thank you for reading.
      chaz_
      • TIGT
        Are you setting the animation's image size/aspect-ration in the Options ?
        If its aspect-ratio matches the screen's then there should be minimal cropping...
        • GaieusG
          Animation can only be exported at 4:3 or 16:9 aspet ratio. This means that if your SU window is different from these ratios, there will always be some cropping.
          I see you are on Windows. First of all, I would recommend this plugin to hide all your toolbars (before they get messed up when you resize your SU window):
          http://forums.sketchucation.com/viewtopic.php?t=42926
          Then this little freebie to resize your SU window so that the inner (model) space is exactl 4:3 or 16:9 (you will need to experiment a bit - try to export a 2D image and set it to export at screen resolution to see what it is):
          http://www.brianapps.net/sizer/
          It works like shown below; you right click on the edge of a window and tell it what size it should be. As you can see, presets can be saved.
