    Model a "infinite"
    8 Posts 5 Posters 615 Views 5 Watching
      luisto
      How can I model this drawing in Sketch-up?
      • Alan FraserA Offline
        Alan Fraser
        I'd start by constructing a solid Moebius strip without any compartments, then use Tools on Surface followed by Joint Push pull to create the hollows.
        The attached skp file shows how ro make the strip. As I point out in the file, it needed a teensy bit more of an offset to allow the two sections to pass each other cleanly...but you get the idea.
        Moebius.skp
        3D Figures
        • hellnbakH Offline
          hellnbak
          Alan, I'm very disappointed that your model wasn't perfect 😒
          JK, nice little tutorial
            luisto
            thanks for helping me . And how can I build the corbels? Thank goodness
              Alan Fraser
              As I said in my original post, use Tools On Surface to draw out the pattern of recesses on the surface...then use the Joint Push Pull script to intrude them.
              3D Figures
                Here front is not not also the bottom 😉
                That is not a Moebius ribbon! 😉
                For that it must have only "one face" 😉 (not included thichness)
                http://www.dvorak.org/blog/wp-content/uploads/2007/07/moebius_escher_anim.gif
                  david.
                  Technically, that object is not a Mobius strip.
                    Alan Fraser
                    I know...on the other hand it's not an infinity sign either...that's 2D. I had to call it something without being too pedantically long-winded. 😉
                    3D Figures
