    Shortcut Assignment Problem
    5 Posts 3 Posters 459 Views 3 Watching
      ABdsInc
      Shortcut issues,
      OS: Mac OSX Lion
      Sketchup 8 Pro
      I cannot find the shortcut.plist file on my Mac, does this even exist? I looked all over the place including, Library/Application Support/Google Sketchup 8/Sketchup...
      When I try to assign shortcuts I repeatedly get the warning that the desired key cannot be assigned. I seem to be able to overwrite my Sketchup.dat file with one that has settings that I like, but if I ever want to change a shortcut assignment I get the same error. Sometimes it lets me reassign a used letter. For example, if P is used for Push I can reassign it to Perspective, but after that change I cannot reassign P to Push (and get the same error message). Once I reassign a letter it becomes unusable for future changes. If I reset all my shortcuts, I cannot assign shortcuts to anything...and get the same error message.
      I have no idea what is going on, but it is incredibly annoying.
      Any help would be appreciated.
      Thanks,
      The warning I get when assigning shortcuts.
        Just a guess. Are you hitting Enter/Return after typing the keyboard shortcut you want to assign? If so, don't. You'll get this if you do hit Enter/Return because that key can't be used as a keyboard shortcut.
          chrisjk
          In my case, when I see that message it seems to be because I have a system-wide shortcut already assigned to the key - check through the shortcuts in system preferences>keyboard to see if something is already assigned there. Also if you have any other shortcut managers running (eg keyboard maestro etc.) then these might affect things.
          Chris
            ABdsInc
            ...wow I feel kinda embarrassed. Thank you Dave, I kept hitting enter or tab to set the shortcut like you said. It's funny how something so obvious was completely unclear at the time.
            Thanks,
              Thanks,
              You're welcome. I did it a couple of times while setting shortcuts early on with my Mac so I have first hand knowledge of the issue. 😳 It's not as intuitive as on the PC.
