    White reflective surface?
    renderpluginsextensions
    12 Posts 4 Posters 4.0k Views 4 Watching
      cmoreink
      This might be a silly question, but how do I get a white reflective surface (not chrome, just plain reflective glossy white surface)? I'm trying to render kitchen with some white cabinets that are white, glossy and reflective. I am πŸ˜•
      Thanks in advance.
      my portfolio
        cmoreink
        I got it 😲
        my portfolio
        • arail1A Offline
          arail1
          A suggestion:
          When you solve a problem, no matter how basic it might be, post your solution.
          Someone searching the forums for 'glossy surface' would find your post but the second entry 'I got it' wouldn't help them at all.
          Just a thought.
          • StinkieS Offline
            Stinkie
            Nomer, why the need for two reflection layers?
            • N Offline
              nomeradona
              i feel what he want is refelctive acrylic plastic, same in lacquer and carpaint maybe. this is my common workflow with this material where the top acts like a glass refelction, and the below reflection will do the rough and blurry something. i dont know how to explain it clearly. downside long rendering time.
              visit my blog: http://www.nomeradona.blogspot.com
              • N Offline
                nomeradona
                here is what you will do. and be sure you make the layer stack like this
                Reflection layer 1 (use fresnel map.. default is ok)
                Reflection Layer ( use fresnel map, but put the ref and highlight glossiness to 0.95. use 16-24 subdivision) filter Acolor white
                Diffuse layer.. white
                • StinkieS Offline
                  Stinkie
                  Ah. Thanks for explaining.
                  • N Offline
                    nomeradona
                    download the material http://sketchupvraymaterials.blogspot.com/2012/02/nomeradonaglossy-enamel-white.html
                    http://1.bp.blogspot.com/-TaGTM77M7FM/T0t6xtsRfOI/AAAAAAAAAFM/en8etngcePo/s320/white%2Bglossy%2Benamel.jpg
                    • N Offline
                      nomeradona
                      oops sorry i did not realized that he solved it.
                        cmoreink
                        Thanks nomeradona for the explantion. What I have done was:
                        1)created new "reflaction" layer
                        2)applied fresnel under BRDRFReflection - Reflection
                        3)hilight glossiness at 0.8 and reflection glossiness 0.85 (adjust to your likings)
                        4)under Maps checked off Reflection
                        done
                        set up white reflective material kitchen
                        work in progress with white reflective material
                        my portfolio
                        • N Offline
                          nomeradona
                          if you will use another fresnel reflection on top your refelction, you will see the reflection will be further enhanced.
                            cmoreink
                            Thanks, I'll try that technique for sure.
                            my portfolio
