    How to do good UV-Mapping? Possible with Sketchup?
    6 Posts 5 Posters 14.5k Views 5 Watching
    • thomthomT
      You could try QuadFace Tools: http://forums.sketchucation.com/viewtopic.php?f=323&t=39442#p348501
      Check the YouTube videos for examples of how to use the UV Mapping Tools.
      • thomthomT
        1. I made it one time and all was fine. The corners fit (after I clicked "Triangulage"), but the texture was irregularly (stretched / compressed) That looks ugly. How can I fix this?
        Can you post example of the result? Easier to exactly tell what is going on.
        • U
          Unknown Target
          Maybe this might help?
          Error 404 (Not Found)!!1
          (sketchup.google.com)
          • Alan FraserA
            Alan Fraser
            The texture is stretched because it's been skewed. You need to skew it bback again. If you have triangulated all those edges, then you'll need to turn hidden geometry on in order to see the two constituaent triangles. Positioning a texture only works on single faces, not two or more that have been smoothed or had their edges hidden.
            3D Figures
            • A
              AlainBo
              Would it be possible to map a earth texture on a sphere.
              I tried it with UVmapping wihtout success but I'm not sure I correctly used it.
              • GaieusG
                Here: http://sketchup.google.com/3dwarehouse/details?mid=bc92eca8611ed04d2470944666440e50
                If you do not like the texture on it, you can reload the material in the Material browser > In model library with your own - UV mapping will remain intact (note that this model is extremely high poly stuff - 90 segments were used instead of the default 24 segments in the circles when the sphere was created so expect some lags in SU).
                It was mapped with this plugin: http://sketchucation.com/forums/viewtopic.php?t=23725
