    Modelling irregular shapes in Sketchup
    6 Posts 5 Posters 4.5k Views 5 Watching
    • E Offline
      eastspringdt
      I was trying to model an irregular shape in sketchup but facing difficulties doing it. Anyone can help?
      The pics are below.
      http://i177.photobucket.com/albums/w233/eastspringdt/2012-02-15101009.jpg
      http://i177.photobucket.com/albums/w233/eastspringdt/2012-02-15100957.jpg
      thanks.
        Something like this?
        http://farm8.staticflickr.com/7037/6889480871_585a2e6d59.jpg
        Sorry. It's impossible.
        Just kidding.
        I just did a rough example to show. First, I only drew 1/5 of it and made that a component. Then I made a radial array with 4 additional copies. The convoluted edge was drawn using the Bezier plugin and the Arc tool. Then I used TIG's Extrude Edges by Rails to create the skin. I did the outside skin that way, copied it up and scaled down the copy slightly. Then I used the same plugin to create the rim.
        • mitcorbM Offline
          mitcorb
          Here is a rough idea, done with no extra tools, in about 30 minutes since I am extra slow.
          The point is, that it is possible. The next steps after cleanup would be to scale copy the curvy bowl maybe 98%, to create the wall thickness then stitch the edge after intersect trim with skewed planes(or tilted circles)and erase away anything that doesn't look like the end product.
          I stopped here just to get something to you.
          • dukejazzD Offline
            dukejazz
            I made a mask and cut it away by a spear to make a bowl
            30 min
            I don't think the other object is that hard to do
            Good luck with your project.
              chrisjk
              Curviloft splines
              http://content.screencast.com/users/chrisjk/folders/Jing/media/112abf02-429a-409b-a5a2-5e8f37d956c0/00000018.png
              Chris
              • E Offline
                eastspringdt
                thanks for all the replies. It's fascinating. It'll take me a while to master it. thanks again
