    Ceiling grid, generator
    10 Posts 4 Posters 2.5k Views 4 Watching
      tspco
      Revisit, does anyone here have a script to create a grid ceiling?
      Something that would generate a 3D "tee" grid?
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • mitcorbM Offline
        mitcorb
        Maybe you could use Windowizer in one of its versions by Rick Wilson. Check at SMustard . com It would be a special case. Maybe a tee shape can be used. Otherwise, make a component, multicopy in two directions. Mains are generally 12 feet long out of the box and tees are 4' long. Perimeter angles probably packaged at 10' long. One foot= 304.8 mm, but nominally 300 mm.
          tspco
          I tried Windowizer3 (free) worked ok but you need to be very specific in the length and width of your ceiling. I tried a 20'x10' area adjusted the rows and columns to 5x5, the result was close, on the 4' sides it measured 3'11 11/16", and on the 2 foot sides it measured 1'11 11/16". Usable, yes, but if yout have an odd, sized/shaped area, the plugin will put the exact number of columns and rows you select and the panels will not measure close enough. It will not place a partial panel in place. And it will not allow other than whole numbers, 4 yes 4.5 no.
          I can see use for its intended purpose though, but I make my own windows and frames.
          Thanks for the suggestion mitcorb
          • mitcorbM Offline
            mitcorb
            May I ask what ceiling panel product were you modeling this on? Since I do mostly commercial design with conventional products due to lots of tight budgets, I work mostly with either 2'x2' or 2'x4'. Not that I wouldn't finagle a nice featured ceiling in the right places. 💚
              tspco
              Just your basic 2x4 suspended ceiling, plain panels, nothing special.
                Why not make a simple 2x4 panel tile as a component [leave off the 'back' geometry if it'll never to be seen]. Make its s.o.p. its center...
                Use some guides in a room to determine it's center and how tiles might be cut.
                Place a 'starter tile' either centered or with its grid centered as might be needed by the layout... and then use Move+Ctrl to copy how many more tiles are needed across the room; select those and copy in the other direction as needed etc.
                Some perimeter tiles will almost certainly clash into walls.
                If so use make_unique on them and edit an instance as a 'cut' tile.
                Use the cut-tiles in other locations if they fit, or otherwise make a further unique cut-tile etc.
                When tiles are 'notched' at columns or external corners etc employ a similar technique to make a unique notched version, reused wherever possible.
                If you have modular ceiling-lights that are also made as components with the same s.o.p. etc as the ceiling-tiles you can swap the instances of the tiles with the lights as needed.
                This makes adjusting layouts easy as tiles/light are easily selected and exchanged.
                If a room changes shape you can also edit one or two perimeter cut-tile instances to update all of them...
                This is relatively easy to do manually, BUT trying to automate it in a tool would be very cumbersome...
                  tspco
                  Thanks Tig but I need to ask about SOP, in my world that is "Standard Operating Procedure". Probably not the same definition in this context.
                    Ryan, do you need the tiles or just the ceiling grid?
                      tspco
                      Just the grid, I can make tiles. It is just a matter of efficiency. I do not do well at tedious activities, that is why I worked maintenance in a industrial plant not the production line.
                      At one time I had found a plugin to do this task, about the same time I found a plugin to make parking lot stall "lines". They are both gone now, as far as I can tell, relics from su 5 and 6 I am guessing.
                      I use a lot of "drywall ceilings" because they are fast, and easy. The reason I am looking for a ceiling grid "maker", is because I may have a paying gig for a cosmetic remodel of a 1910 building. It has an existing suspended ceiling on the main floor, that needs redone.
                        In the UK it's the Setting Out Point... 😒
