    Triangulate points plugin making a bed sheet
    3 Posts 2 Posters 503 Views 2 Watching
      mwm5053
      In watching this video on YouTube http://www.youtube.com/watch?v=wIcHHsjQ-Mo&feature=results_main&playnext=1&list=PL12BA2A43AB281E16
      I'm not getting the same outcome not sure why. Thanks for the help.
      bedsheet.skp
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        A delauney algorithm is used to work out how to triangulate points.
        It's typically used to make site meshes.
        Your points-set includes several points that are located immediately above others.
        This causes delauney to 'fail' and produce something that's not like you expected; or more exactly it gives a valid interpretation of the points data - but it's just there are many valid interpretations and the one you want is only ever going to get made once in a zillion tries !
        So... to get a delauney triangulation to work first go, you must make sure that there are no points exactly above one another: so, move some points slightly or select a set and scale them very slightly about a center [ctrl] so that none of the points-set align vertically.
        If you look at the video-tutorial you will see that after the editing there are no points vertically above others when the triangulated mesh is made...
          mwm5053
          Thanks TIG
          2011 iMac
          V2 Twilight
