    Wacom Pen in SketchUp?
    47 Posts 25 Posters 21.6k Views 25 Watching
    • K Offline
      kaas
      @mistro11 said:
      ...I would like to know a good effective way to assign buttons.
      I switched to a simple bamboo a while ago and it works perfect in SketchUp. My setup is:
      • richt-click on the pen is richt-click: the context menu's are too nice to give up.
      • left-click on the pen is middle-click. Hovering over the tablet while pressing left-lick = orbit & with shift = pan.
      • I don't use the buttons on the tablet it self.
      • for staring tools in Sketchup I use a combination of clicking the menus/icons or using the keyboard shortcuts.
      The above works really fast and easy for me. Working for quite some hours at a time is far more easy on my wrist compared to using a mouse.
      • N Offline
        nickchun
        I have had the same problem with 'mouse ache' in the shoulder and have tried a cheap pen and tablet in conjunction with a Razer Nostromo gaming pad for shortcuts on the left hand. The Razer speeds things up a lot but the problem is quick zoom and orbit when using the pen. Ended up re assigning the buttons on the razer for zoom and orbit and fitting a sturdy tray under the desk to get arms at right height.
        Has anyone used the touch capability on the Wacom to rotate and zoom? Would it work on SU?
        Also looked at vertical mouse but thought might not be as easy to make small movements for accuracy. Anyone tried that?
        • john2J Offline
          john2
          I bought today a wacom one tablet. It's working fine in illustrator and photoshop. However, when i try to use it in sketchup pro 2014, it doesn't work. What should I do? Strangely, when I press the down button of pen and drag up and down on the tablet surface, I'm able to zoom in and zoom out realtime. But I can't draw anything in SketchUp. I've tried with all commands. Even I can't get the cursor to move.
            I'd start with Wacom's tech support. You should have some tech support from them available.
            Very likely you need to make some adjustments to settings for the tablet and pen in the tablet's panel.
            • Mistro11M Offline
              Mistro11
              I ended up returning that CTH 680 for the Intuos Pro Medium. Cost more but it has more buttons for customization in programs a pen holder and wireless kit included. I"m getting used to using it in SU. The best thing I'm experiencing is I finally find the freehand drawing tool very useful. Making freehand contours and actually drawing on a surface is a breeze now.
              John2- If your tablet can support it, check the properties to see if you can bring up Sketchup in a list to customize commands.
              i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
              Structural Integrity is Not Just Physical...It's in the Design and Purpose
              • H Offline
                hermyboy3000
                I've been using Sketchup with a Cintiq 21UX for years now and I love it. As great as the 21UX is, my new mobile option, a Cintiq Companion, is having a one quirky issue with right-click context menus. When I click the right pen button (back toggle), I have to move the cursor ever so slightly to activate the menu. This is a slight bug that I need to work around or get used to I guess. The ease of use and natural interfacing with the rest of the design software I use makes this bug seem insignificant.
                • sicksickisckS Offline
                  sicksickisck
                  yes in sketchup zoom function suxxl 🀒 ; shortcut system is very old; but anyway I like have set [shift]+ [ctrl]+ [alt]+[spacebar] for "camera/zoom" in my wacom drivers β˜€
                  • 3 / 3
