    Colors problem!
    renderpluginsextensions
    4 Posts 2 Posters 669 Views 2 Watching
      LorenzoS
      Hi all!
      I have this problem: the gradient is divided into steps which have strange colors, like there are waves and not a linear gradient.
      How can I get an higher resolution in colors?
      Please find in attached the scene.
      thx for the help!
      • eidam655E Offline
        eidam655
        if it's a texture, i'd say you'd need higher bit depth (from 8 to 16 for example).
        but since it's more probably a VRay setting, i'd ask you to share the settings you use for global illumination - looks like light cache is used for the primary engine. that can cause similar 'cracks.'
        otherwise i'm out of ideas for now...
        I'm using SketchUp 2017, V-Ray 3.4
          LorenzoS
          hi!
          it is not a texture.... just plain color.
          You can find the lights setting attached here http://www.serraglia.com/test/color_test.visopt.zip.
          and the scene in attached down.
          I am using Irradiance Map and Light Cache as secondary.
          GI at 0,1 with no sky, because I am using a rectangular light (subdiv 8 or 16 no difference...)
          This problem makes me crazy
          Thx for the help!
          test col.skp
          • eidam655E Offline
            eidam655
            could it be resolved by turning on or switching the type of the antialiasing filter in Image Sampler?
