    Google Sketchup Exporting Issues
    6 Posts 2 Posters 2.6k Views 2 Watching
      TeamSDA
      We have just recently upgraded to Sketchup 8 and are experiencing some animation exporting issues. We are on Sketchup 8.0.11751.
      All my export settings and file info are listed below. In Sketchup 7 these export settings worked but since the update it crashes. If the frame rate is switched to 24 FPS the export works.
      Does anyone have a resolution to solve this issue?
      FILE INFO
      Edges: 1,262,536
      Faces: 473,863
      Total Scenes: 11
      Transition Time: 4 seconds
      Delay Time: 0 seconds
      Export Format: Quicktime Movie
      Width: 1920
      Height: 1080
      Frame Rate: 30
      Loop to starting page: No
      Anti-alias: Yes
      Transparent Background: No
      Compression type: Animation
      Key frames every: 24
      Depth: Millions of colors
      Quality: Best
      Thank you for your help,
      TeamSDA_Christian
        TeamSDA
        Hi All,
        We are able to make exports using the H.264 compression type at all the same settings. As well as make an export using the Animation compression type but with the width and height at 160 x 90.
        Does anyone have any input as to what is going on?
        TeamSDA_Christian
          TeamSDA
          Hi All,
          Attached is an example file. When I try exporting a large format animation Sketchup crashes.
          Width: 1920
          Height: 1080
          Frame Rate: 30
          Anti-alias: Yes
          Quality: Best
          TeamSDA_Chrisitian
          Example Of The Issue
            I only have a PC and that makes AVIs, also a few of your settings are not directly transferable [Codec etc], however, I have successfully made the movie in less than 45 minutes !
            It was ~247Mb !!
            Have you tried adjusting your settings ?
              TeamSDA
              Hi TIG,
              Using the Animation codec. I can export a video from the example file at 5, 10, 12, and 15 frames per second. Once it gets to 24 or higher can't export. No order settings seem to make a difference.
              Christian
                Do you have other possible codecs ?
                I managed the max 30 fps OK with Cinepac Radius Codec [but PC though]
                πŸ˜•
