    Shaderlight vs Maxwell
    extensions
    4 Posts 4 Posters 1.2k Views 4 Watching
      magentarabbit
      Hello, can anyone tell me what the difference in quality and render time there is between Shaderlight 2.1 pro and Maxwell for Sketchup licensed.
        MrMikeEsq
        I don't use either, but shaderlight is biased and maxwell is unbiased. This basically means that maxwell will calculate the lighting much more realistically/accurately but will take longer to produce a clear/un-grainy image. Biased engines like shaderlight are quick but wont be as instantly realistic (then again if you know what you're doing you can get great images out of both)
        • gtalaricoG Offline
          gtalarico
          Haven't used shaderlight, but I use maxwell a lot and I love it...
          (I guess that makes me biased too.... πŸ˜† )
          Renders do take a long time, but then again you also save time with an easy and intuitive scene setup (imho)....
          -Gui
          http://www.gtalarico.com
          • Z Offline
            Zoom123
            I made a quick test of Shaderlight 2.0 and Maxwell for SU along with a few other apps a while ago:
            http://forums.sketchucation.com/viewtopic.php?f=80&t=41848
            I found a few issues with Shaderlight and the results were not as realistic but it is faster than Maxwell.
