    Lumen RT Plugin not working
    extensions
    25 Posts 6 Posters 17.5k Views 6 Watching
      Syndicate
      I hit the export to Lumen Rt button, I get a dialog box asking me to export the selected model or not. Either answer I choose the box goes away and then nothing.
      Women have the last word in arguments. Anything said after that is the beginning of a new argument.
      • N Offline
        Nicholas Phelps
        IS this happening with all models, or one in particular?
        What happens if you try to export the empty SketchUp startup scene? Do you see the LumenRT interface?
          Syndicate
          Thanks Nicholas for the reply. I tested it with an empty scene, only the female standing there. Nothing selected, upon export, nothing happens. If I select her, and then hit Export, I get the dialog box again. When I choose any option, the box again goes away and nothing happens. This is also the trial version of Lumen Rt I downloaded. One more thing. As I was installing Lumen Rt, I opened Sketchup to check it out, it had realized that some parts of the plugin were already installed and gave me an error about certain files missing. I realized why it did that. I closed Sketchup and waited for the Lumen install to complete. Re-opened Sketchup with no errors but now the plugin doesnt work. Should I re-install Sketchup?
            Syndicate
            I tried that already to no avail 😐
            • N Offline
              Nicholas Phelps
              Yes, sounds very much like a problem during install. But before you re-install SketchUp, I'd recommend you just try re-installing LumenRT first. Maybe uninstall it first, just in case.
              • N Offline
                Nicholas Phelps
                Hmm. Well then if that's not too much of a hassle, could you try uninstalling LumenRT, then uninstall SketchUp, and then re-install both products?
                  Syndicate
                  Will do.
                    Syndicate
                    One thing I forgot to mention. Sketchup is 32-Bit, the plugin is 64. Does this make a difference?
                      Syndicate
                      Thats a no go Nicholas. Still nothing πŸ˜•
                      • N Offline
                        Nicholas Phelps
                        Re 32 vs 64 bit: That's not a problem, since LumenRT is launched as a separate application.
                        I don't understand the cause of your problem.
                        To clarify, does the LumenRT interface appear inside of SketchUp, when you select it from the plug-in menu or click the LumenRT icon?
                          Syndicate
                          The interface does not show up. Ive attached an image of what I get. Also, I have ran setup with admin rights on both the 32 and 64 bit. Maybe Ive got a bad trial installer?
                          All I get
                          • N Offline
                            Nicholas Phelps
                            Maybe a bad download. What happens if you have nothing selected in the scene when you invoke LumenRT?
                              Syndicate
                              If nothing is selected when I invoke Lumen Rt 2, then I dont even get the popup like in the pic. Nothing at all happens.
                              • N Offline
                                Nicholas Phelps
                                Do you have other plug-ins inside of SketchUp? Is JAvascript disabled by any chance? I've heard of possible interactions with JS...
                                  Syndicate
                                  Its a barebones Sketchup install. The only plugin is LumenRT. I forgot how to check for Javascript enabled?
                                  • N Offline
                                    Nicholas Phelps
                                    I think it has to do with your browser settings. Not sure, though, sorry.
                                      dburdick
                                      Hi Syndicate,
                                      Lets do a test.
                                      Try loading in a bigger model to test LumenRT - like a house from 3D Warehouse or something. Then , lets open up the ruby console by going to Window --> Ruby Console.
                                      Now, don't select anything in the scene, just go the menu Plugins --> LumenRT --> Export Full Model.
                                      You should then see the export user interface:
                                      http://www.skinvue.net/LRTExportUI.jpg
                                      If you don't see this interface, check to see what the Ruby Console is showing.
                                      Dave
                                        Syndicate
                                        The interface didnt popup but heres what the console says:
                                        Error: #<Errno::EACCES: Permission denied - D:/Program Files/e-on software/LumenRT 2/LumenRT/Ruby/Settings.ini>
                                        (eval):1844:in initialize' (eval):1844:in open'
                                        (eval):1844:in save_Settings' (eval):1862:in get_SavedSettings'
                                        (eval):1636:in initialize' (eval):192:in new'
                                        (eval):192:in lumenRT_exportModel' (eval):278:in load'
                                        (eval):1844:in `call'
                                        (eval):1844
                                          Syndicate
                                          This is ridiculous. Sorry, Dave, didnt see your reply. Ill try this.
                                            Syndicate
                                            FIXED!!! I realized that the console told me the settings.ini file was denied permission. I used a handy little tool called "Take Own" and took ownership of the LumenRT 2 folder and Voila!
                                            • 1 / 2
