    Lumen RT Plugin not working
    extensions
    25 Posts 6 Posters 18.1k Views 6 Watching
      Syndicate
      I tried that already to no avail 😐
      Women have the last word in arguments. Anything said after that is the beginning of a new argument.
      • N
        Nicholas Phelps
        Yes, sounds very much like a problem during install. But before you re-install SketchUp, I'd recommend you just try re-installing LumenRT first. Maybe uninstall it first, just in case.
        • N
          Nicholas Phelps
          Hmm. Well then if that's not too much of a hassle, could you try uninstalling LumenRT, then uninstall SketchUp, and then re-install both products?
            Syndicate
            Will do.
              Syndicate
              One thing I forgot to mention. Sketchup is 32-Bit, the plugin is 64. Does this make a difference?
                Syndicate
                Thats a no go Nicholas. Still nothing πŸ˜•
                • N
                  Nicholas Phelps
                  Re 32 vs 64 bit: That's not a problem, since LumenRT is launched as a separate application.
                  I don't understand the cause of your problem.
                  To clarify, does the LumenRT interface appear inside of SketchUp, when you select it from the plug-in menu or click the LumenRT icon?
                    Syndicate
                    The interface does not show up. Ive attached an image of what I get. Also, I have ran setup with admin rights on both the 32 and 64 bit. Maybe Ive got a bad trial installer?
                    All I get
                    • N
                      Nicholas Phelps
                      Maybe a bad download. What happens if you have nothing selected in the scene when you invoke LumenRT?
                        Syndicate
                        If nothing is selected when I invoke Lumen Rt 2, then I dont even get the popup like in the pic. Nothing at all happens.
                        • N
                          Nicholas Phelps
                          Do you have other plug-ins inside of SketchUp? Is JAvascript disabled by any chance? I've heard of possible interactions with JS...
                            Syndicate
                            Its a barebones Sketchup install. The only plugin is LumenRT. I forgot how to check for Javascript enabled?
                            • N
                              Nicholas Phelps
                              I think it has to do with your browser settings. Not sure, though, sorry.
                                dburdick
                                @syndicate said:
                                I hit the export to Lumen Rt button, I get a dialog box asking me to export the selected model or not. Either answer I choose the box goes away and then nothing.
                                Hi Syndicate,
                                Lets do a test.
                                Try loading in a bigger model to test LumenRT - like a house from 3D Warehouse or something. Then , lets open up the ruby console by going to Window --> Ruby Console.
                                Now, don't select anything in the scene, just go the menu Plugins --> LumenRT --> Export Full Model.
                                You should then see the export user interface:
                                http://www.skinvue.net/LRTExportUI.jpg
                                If you don't see this interface, check to see what the Ruby Console is showing.
                                Dave
                                  Syndicate
                                  The interface didnt popup but heres what the console says:
                                  Error: #<Errno::EACCES: Permission denied - D:/Program Files/e-on software/LumenRT 2/LumenRT/Ruby/Settings.ini>
                                  (eval):1844:in initialize' (eval):1844:in open'
                                  (eval):1844:in save_Settings' (eval):1862:in get_SavedSettings'
                                  (eval):1636:in initialize' (eval):192:in new'
                                  (eval):192:in lumenRT_exportModel' (eval):278:in load'
                                  (eval):1844:in `call'
                                  (eval):1844
                                    Syndicate
                                    This is ridiculous. Sorry, Dave, didnt see your reply. Ill try this.
                                      Syndicate
                                      FIXED!!! I realized that the console told me the settings.ini file was denied permission. I used a handy little tool called "Take Own" and took ownership of the LumenRT 2 folder and Voila!
                                        dburdick
                                        Glad you got it working - let us know what you think after your test runs.
                                        Regards,
                                        Dave
                                        • W
                                          whiterabbit
                                          I have same issue. no export function suddenly, tried a reinstall too.
                                          below is the ruby info. Only material editor appears. No export from dropdown menu or from lumenrt buttons. If I have a selection I do get the window that asks if I want to export the whole model or just the selection, but either way...nothing happens.
                                          Setting Default Settings
                                          Error: #<NoMethodError: undefined method strip' for nil:NilClass> (eval):2295:in get_SavedSettings'
                                          (eval):2292:in each' (eval):2292:in get_SavedSettings'
                                          (eval):1926:in initialize' (eval):241:in new'
                                          (eval):241:in lumenRT_exportModel' (eval):552:in load'
                                          (eval):2296:in `call'
                                          (eval):2296
                                            dburdick
                                            Hi WhiteRabbit,
                                            Look like the Setting.ini may be corrupted. Go to ProgramFiles/LumenRT 4 Studio/LumenRT/Skp/Ruby and delete the Settings.ini file. Then, restart Sketchup and try firing up LRT again. It will create a new Settings.ini file.
