    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Axes Widget?
    26 Posts 7 Posters 2.0k Views 7 Watching
      OK, but what other 'hidden' gems do we have to find ?
      The secret-menu item for ray_trace_rendering... etc... ๐Ÿ˜†
        chrisjk
        http://content.screencast.com/users/chrisjk/folders/Jing/media/da7f38a1-cb41-413d-a9fd-b59edeebdf09/00000011.png
        Only on a Mac though... ๐Ÿ˜„
        Chris
        • N Offline
          nickchun
          Holy cow! Just came back from work and caught up with the post. will have to have a look in the menus.
          • N Offline
            nickchun
            Thanks for your help guys, opted for the shortcut..'by axes' ๐Ÿ‘
            • H Offline
              harnstein
              Two things to add..
              First, did i get you guys right that you didn't know about the "axis by material" setting??
              If your still searching for where it's to be found- it's in "Styles>Edit>Edges>(bottom)By Color/Axis/Material"
              ..probably i was just too "dooh" to get the point of this tread. ๐ŸŽ‰
              Second, one good thing not to get lost in space is to draw one big rectangle, group it
              and give the upper side a different color (if not already by default material.
              This way you will know where you are ๐Ÿ˜‰
              Another benefit of doing that:
              If you're drawing somewhere within space and you're pointing on a object you want to scroll to you may miss it.
              Or you're pointing to some lines only (not faces) then it's hard to get where you want to.
              Sometimes you don't get to the object or only slowly, sometimes you pass by the object way to quick.
              (That's why i do it like this and it works pretty well.)
              Btw, nice one, Chris. ๐Ÿ˜„
              still sketchin'
              • Wo3DanW Offline
                Wo3Dan
                The Axes tool interrups an operation. So assigning the shortcut sequence to a key allows you to see where blue is pointing at. [Ecs] ends the interruption.
                I must admit, not as useful as
                toggling 'Color: by axis <> all the same'.
                I've always wondered why toggling endpoint's visibility on/off isn't available in the 'View' menu, nor in the shortcut list discussed here.
                Unlike profiles, depth cue and extentions. It's just missing!
                We always have to dig into Window > Styles > Edit > Edge settings to reach it. Or have it saved in a scene. Toggling by pressing one key would help.
                (mentioning this at the risk of now being "sentenced" to contribute to the 'Dooh' thread) ๐Ÿ˜’
                • 2 / 2
