    Soap bubble help
    7 Posts 3 Posters 471 Views 3 Watching
    • O
      oneturboneeded
      Ok I am trying to use soap bubble on the tale of my model and it says that the 4 lines im picking are not in a closed group? Any reason? I dont see any thing wrong.plane skinning.skp
      • O
        oneturboneeded
        Eebyrails is great but leaves a weird bump and i dont know how to fix it.
        • TIGT
          Try this approach...Capture.PNG If you also try to have the same number of segments [and ~same length] in each Rail, then the result would also be much smoother/better ?
          • O
            oneturboneeded
            Thank you Tig for all of your help. With that way it looks like the profile is round and the lines i have now denote the form of the skin to curve so that it gives more head room.
            • O
              oneturboneeded
              Instead of soapskin I added another rail and now I like the profile now I would like to eleminate the lines any ideas how? this is what I have.
              plane skinning 3.skp
              • mitcorbM
                mitcorb
                Do you mean to eliminate the lines you used as rails? If so, they should stand alone when you select and move the grouped geometry away from them.
                • O
                  oneturboneeded
                  Thankyou that worked great for leaving the rails behind but now how do i eleminate the lines left behind on my surface?
