    Model Hops Around
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    3 Posts 3 Posters 8.0k Views 3 Watching
      Jim57
      When I leave Layout and go back to SketchUp to edit my model, the model shifts in the Layout viewport.
      The edit can be pretty minor, and does not involve moving the model.
      The model then shifts about 12" to the left and down on a 36 x 42" document. The viewport seems to remain the same size, but moves also, in a different direction and amount. Dimensions stay attached to the model shift with it, somewhat.
      Jim
      Layout 3.0.11751
      OS 10.6.8
        If you have the LO view linked to a Scene-tab it should remain constant, although changing the size of the SKP window may affect LO when reloaded - changing from a full-screen window or adding/removing docked toolbars might affect this size/view extent.
        If the scene-tab hasn't changed then the LO linked view should not change either πŸ˜•
        • elmerE Offline
          elmer
          Hi Jim,
          Have a look at this thread:
          http://forums.sketchucation.com/viewtopic.php?f=12&t=42752
          Might help you to solve your problem which is not really a bug.
