    Render - criticisms and suggestions please
    renderpluginsextensions
    6 Posts 3 Posters 526 Views 3 Watching
    • john2J Offline
      john2
      my render is looking unrealistic and lacks the realism..i added glass too but it looks flat. im using default settings. what do you guys advice
      • andybotA Offline
        andybot
        put together a context. The image is floating in space. If you have some street views, you can even make some simple cutout "billboards" just to give some images for the window to reflect. Look at some example renderings. I find using photomontage is the quickest was to give a render "realism"
        Best,
        Andy
        • john2J Offline
          john2
          well actually i see a lot of images with absolutely no context..but still they look nice. e.g. this
          http://forums.sketchucation.com/download/file.php?id=76567&mode=view
          • andybotA Offline
            andybot
            well, then zoom in on your building, it's that easy... My point is that the view you posted of your building has it floating in the air. The one you refer has a ground plane and some notion of how it sits on the ground.
              rspierenburg
              The modelling looks really nice, but I agree with Andybot. Perhaps a different camera angle, something closer to what a person would see real-world. This will help the realism. Another suggestion would be to look at your textures. Texturing is just as important (if not more so) as modelling. For example the texture at the front entrance is very repetitive. Finally, lighting. Perhaps move the sun around a little to make the shadows a little more dramatic. Even adding in some ground plane with some vegetation (trees etc) will help cast some interesting shadows on the facade of the building. Once again though, the modelling seems nice and clean and pretty intricate.
              • john2J Offline
                john2
                thanks. πŸ˜„ ...although i know there'sbeen a lotta triangulation of simple rectangle faces..making model untidy..vray ignores those bad lines that come πŸ˜‰
