Dude... Did you know the updated Vue Exporter...
Dude... Did you know the updated Vue Exporter handles animations from Google to Vue? camera positions and scenes... awesome... someone around here wrote this... I forget who but thanks for what you do.
here's some of the other new features.
Key features of the Plugin include (Version 10 Update – 12/01/2011):
Exports from Sketchup Pro or Sketchup Free
Works with all Artist and Professional level versions of Vue (version 8.4 and later)
Full scene export including model geometry, scene hierarchy, sun direction, and cameras
Accurate conversion of the Sketchup model hierarchy with full naming and preservation of parent-child component relationships
High degree of material appearance correlation with automated transparency and bump
NEW! Ability to set Vue material properties directly in Sketchup materials
Automatic handling of single-sided Sketchup faces (e.g. faces with different materials on each side)
Support for Sketchup geometries, components and groups
Exploding the model is not necessary
Export the full model or selected portions of the model
NEW! Export and automatic conversions of Sketchup animations directly into Vue animations
NEW! Automatic conversion of Sketchup water materials into animated Vue water materials
NEW! Utilities for automatically setting object and component pivot points in Vue to aid in proxy replacement -
The new exporter is great. Although I exported a model on the heavy side the other day and the thing ran like a dog in Vue. I thought it was supposed to handle hi-polys with ease. It was so hard to work with the import that I almost gave up on it. My total model was just over a million poly's with 12000 objects.
I use tak2hata's obj exporter. It works way better than that stupid plugin I bought at Cornucopia.
It even smooths out the curves.
valerostudio, I use thomthom's cleanup script from here, works great also.
Really reduces the file size for importing into Vue.
tak2hata exporter....
http://onigiriburning.so.land.to/
thomthom's cleanup...
http://forums.sketchucation.com/viewtopic.php?t=22920 -
What about TIGs exporter? http://forums.sketchucation.com/viewtopic.php?t=33448
