Using Revit .rfa files
Is there a way to use Revit *.rfa files in SU? Was hoping that there is a file conversion tool out there. I want to use components from a window manufacturer that are only offered in this file format.
Thx,
Marc -
Not that I know of; but you can download Revit as a trial for a month to convert them.
No... but you can export Revit stuff as other formats - DWG/DXF [FBX/3DS ?] etc which could then be imported into a SKP.
BUT then you need Revit and a PC!A manufacturer who limits themselves in this way is being ill-advised...
Why not suggest to them alternative file formats...I have also PMd you...
Hello, I want to ask you.. This topic is from 2012. Is there any way to import/use rfa. format now ? Or it is still a problem. Thank you.
Register LoginAdvertisement
