    [Plugin] Slicer5
    338 Posts 83 Posters 343.9k Views 82 Watching
      Version 5.11, can not be achieved slice tile, without any prompting!
      Let me try to recast what you said, as I understand it...
      Version 5.11, does not make slices, without any error messages...
      If has a toolbar and menu items, and you have a saved SKP, with just one group selected, and you run the tool... what happens ???
      Because it is working successfully for me [and many hundreds of other users] then it suggests that you have something wrong in your installation.
      Please try reinstalling everything.
      Ensure that there are no copies of the files that should be in the tool's subfolder inside the Plugins folder by mistake.
      There should be two files in the Plugins folder
      Slicer.rb deBabelizer.rb
      and a subfolder named
      TIG-Slicer
      containing
      TIG-Slicer.rb
      and the 8 PNG image files for the toolbar buttons
      and the 6 lingvo files...
        I've noticed an error with the 'Portuguese' lingvo file that was recently supplied with v5.11
        It's incorrectly named 'PO' and it contained no translations anyway ! 😮
        Here's the correct 'PT' version.TIG-SlicerPT-lingvo.zipExtract it from the zip.
        If you want Portuguese translations, please remove the incorrect 'PO' version and add this correct 'PT' one to the tool's subfolder. If your 'locale' is not 'PT' you can always change that part of the name to suit...
        • guanjinG Offline
          guanjin
          Here's the correct 'PT' version.[attachment=0:2ob4u420]<!-- ia0 -->TIG-SlicerPT-lingvo.zip<!-- ia0 -->[/attachment:2ob4u420]Extract it from the zip.
          I may not know the expression, films can not be razed to the ground piece, thank you
          I come from China, is to learn
          • guanjinG Offline
            guanjin
            Here's the correct 'PT' version.[attachment=1:zqav1736]<!-- ia1 -->TIG-SlicerPT-lingvo.zip<!-- ia1 -->[/attachment:zqav1736]Extract it from the zip.
            Translated into Chinese, it can not achieve the flattening function, the following documents attached to the Chinese language, thank you! !
            [attachment=0:zqav1736]<!-- ia0 -->TIG-SlicerZH-CN.zip<!-- ia0 -->[/attachment:zqav1736]
            TIG-SlicerZH-CN.zip
              OK.
              What you are saying is that when using a Chinese lingvo file the 'Flattening' function fails.
              If you change the translation for the 'Flattening' parts of the lingvo back to the original file's text, does it then work ?
              If so, then it suggests that some 'characters' in your translation are not working properly.
              Did you use the 'UFT-8' option when saving the Chinese lingvo file ?
              The translate strings go inside " " in the code, so you can't include any " in the translation, as it breaks the way the code reads it in...
              Can you try alternative 'wording' ?
              • guanjinG Offline
                guanjin
                Here's the correct 'PT' version.[attachment=1:r7efhnet]<!-- ia1 -->TIG-SlicerPT-lingvo.zip<!-- ia1 -->[/attachment:r7efhnet]Extract it from the zip.
                [attachment=0:r7efhnet]<!-- ia0 -->TIG-SlicerZH-CN.zip<!-- ia0 -->[/attachment:r7efhnet]
                I am really stupid, I did not expect this problem, thank you! 😒
                • guanjinG Offline
                  guanjin
                  Here's the correct 'PT' version.[attachment=1:165j53cw]<!-- ia1 -->TIG-SlicerPT-lingvo.zip<!-- ia1 -->[/attachment:165j53cw]Extract it from the zip.
                  Delete the wrong file, sorry!
                  • guanjinG Offline
                    guanjin
                    @tig said:
                    OK.
                    Thank you TIG, problem solved, thank you for your guidance! Thank you! !
                    • guanjinG Offline
                      guanjin
                      Hello TIG: plug-in menu bar, the ability to fold? Thank you
                        [attachment=0:2u7rviwa]<!-- ia0 -->QQ截图20120120162611.jpg<!-- ia0 -->[/attachment:2u7rviwa]
                        I assume by 'fold' you mean 'combine into a single submenu'. 😕 [Do you use Google Translate?]
                        To make that you'll need to recode the menu making part of the script.
                        Here is how to do it.
                        the original code [around line#669] looks like this:
                          UI.menu("Plugins").add_item(cmd)
                          UI.menu("Plugins").add_item(cmds)
                          UI.menu("Plugins").add_item(cmda)
                          UI.menu("Plugins").add_item(cmdx)
                        This is it recoded with an extra line to make the submenu within the 'Plugins' menu; and the other four lines adjusted to add their commands into that rather than directly into the 'Plugins' menu:
                          submenu=UI.menu("Plugins").add_submenu(S5+"...")
                          submenu.add_item(cmd)
                          submenu.add_item(cmds)
                          submenu.add_item(cmda)
                          submenu.add_item(cmdx)
                        The 'S5' constant is the deBabelized string for 'Slicer5', used as the name for the submenu plus '...'.
                        If users would prefer this method I could incorporate it into a new release.
                        So feedback please...
                        • guanjinG Offline
                          guanjin
                          @tig said:
                          [attachment=0:7wcsfm32]<!-- ia0 -->QQ截图20120120162611.jpg<!-- ia0 -->[/attachment:7wcsfm32]
                          The 'S5' 'constant is the deBabelized string for 'Slicer5', used as the name for the submenu plus '...'.
                          This can shorten the length of plug-ins drop-down menu!
                          • guanjinG Offline
                            guanjin
                            Thank you TIG
                            • guanjinG Offline
                              guanjin
                              Want to smooth the edges the better!!
                                The more facets that the sliced object has the smoother the edges of the slices...
                                  Guanjin
                                  Could you post your Chinese lingvo file [zipped] for other fellow users to benefit from - it's only fair - the rest of the tool is freely shared... 😕
                                    Here's v5.12 http://forums.sketchucation.com/viewtopic.php?p=374969#p374969
                                    Extra traps added for 'non-instances' within slice-collections [e.g. when slotting after editing].
                                    Code CONSTANTS added for optional menu-location/single-submenu.
                                    The lingvo files are now all UFT-8 encoded, to avoid problems when copying.
                                    Typos in the FR lingvo file corrected, the correct PT Portuguese lingvo is now included.
                                    • guanjinG Offline
                                      guanjin
                                      Yes, I posted on there?
                                        Bertier
                                        massively awesome !
                                          Thanks to Guanjin here's the Chinese lingvo file.
                                          Unzip it and put it into the TIG-Slicer subfolder in the Plugins folder...TIG-SlicerZH-CN-lingvo.zip
                                          It will be included in the zipped package, with future updates too...
                                            Here's v5.13 http://forums.sketchucation.com/viewtopic.php?p=374969#p374969
                                            The latest Chinese lingvo file is now included in the set.
                                            The RZ solutions have been improved: now less prone to error with complex shapes made when the ORIGIN is within the bounding-box of the sliced-object: useful when making horizontal Z[blue] slotted-ribs with R[amber] radially arranged slotted-spars in the vertical [rotate the slice-object onto its 'nose', if you want to transpose the rib/spar arrangements]...s5-13.PNG
                                            • 6
                                            • 7
                                            • 16
                                            • 17
                                            • 5 / 17
