    [Plugin] Slicer5
    338 Posts 83 Posters 394.1k Views 82 Watching
    • guanjinG
      guanjin
      @tig said:
      I've noticed an error with the 'Portuguese' lingvo file that was recently supplied with v5.11
      It's incorrectly named 'PO' and it contained no translations anyway ! 😮
      Here's the correct 'PT' version.[attachment=1:zqav1736]<!-- ia1 -->TIG-SlicerPT-lingvo.zip<!-- ia1 -->[/attachment:zqav1736]Extract it from the zip.
      If you want Portuguese translations, please remove the incorrect 'PO' version and add this correct 'PT' one to the tool's subfolder. If your 'locale' is not 'PT' you can always change that part of the name to suit...
      Translated into Chinese, it can not achieve the flattening function, the following documents attached to the Chinese language, thank you! !
      [attachment=0:zqav1736]<!-- ia0 -->TIG-SlicerZH-CN.zip<!-- ia0 -->[/attachment:zqav1736]
      TIG-SlicerZH-CN.zip
        OK.
        What you are saying is that when using a Chinese lingvo file the 'Flattening' function fails.
        If you change the translation for the 'Flattening' parts of the lingvo back to the original file's text, does it then work ?
        If so, then it suggests that some 'characters' in your translation are not working properly.
        Did you use the 'UFT-8' option when saving the Chinese lingvo file ?
        The translate strings go inside " " in the code, so you can't include any " in the translation, as it breaks the way the code reads it in...
        Can you try alternative 'wording' ?
        • guanjinG
          guanjin
          Here's the correct 'PT' version.[attachment=1:r7efhnet]<!-- ia1 -->TIG-SlicerPT-lingvo.zip<!-- ia1 -->[/attachment:r7efhnet]Extract it from the zip.
          [attachment=0:r7efhnet]<!-- ia0 -->TIG-SlicerZH-CN.zip<!-- ia0 -->[/attachment:r7efhnet]
          I am really stupid, I did not expect this problem, thank you! 😒
          • guanjinG
            guanjin
            Here's the correct 'PT' version.[attachment=1:165j53cw]<!-- ia1 -->TIG-SlicerPT-lingvo.zip<!-- ia1 -->[/attachment:165j53cw]Extract it from the zip.
            Delete the wrong file, sorry!
            • guanjinG
              guanjin
              @tig said:
              OK.
              Thank you TIG, problem solved, thank you for your guidance! Thank you! !
              • guanjinG
                guanjin
                Hello TIG: plug-in menu bar, the ability to fold? Thank you
                  [attachment=0:2u7rviwa]<!-- ia0 -->QQ截图20120120162611.jpg<!-- ia0 -->[/attachment:2u7rviwa]
                  I assume by 'fold' you mean 'combine into a single submenu'. 😕 [Do you use Google Translate?]
                  To make that you'll need to recode the menu making part of the script.
                  Here is how to do it.
                  the original code [around line#669] looks like this:
                    UI.menu("Plugins").add_item(cmd)
                    UI.menu("Plugins").add_item(cmds)
                    UI.menu("Plugins").add_item(cmda)
                    UI.menu("Plugins").add_item(cmdx)
                  This is it recoded with an extra line to make the submenu within the 'Plugins' menu; and the other four lines adjusted to add their commands into that rather than directly into the 'Plugins' menu:
                    submenu=UI.menu("Plugins").add_submenu(S5+"...")
                    submenu.add_item(cmd)
                    submenu.add_item(cmds)
                    submenu.add_item(cmda)
                    submenu.add_item(cmdx)
                  The 'S5' constant is the deBabelized string for 'Slicer5', used as the name for the submenu plus '...'.
                  If users would prefer this method I could incorporate it into a new release.
                  So feedback please...
                  • guanjinG
                    guanjin
                    @tig said:
                    [attachment=0:7wcsfm32]<!-- ia0 -->QQ截图20120120162611.jpg<!-- ia0 -->[/attachment:7wcsfm32]
                    The 'S5' 'constant is the deBabelized string for 'Slicer5', used as the name for the submenu plus '...'.
                    This can shorten the length of plug-ins drop-down menu!
                    • guanjinG
                      guanjin
                      Thank you TIG
                      • guanjinG
                        guanjin
                        Want to smooth the edges the better!!
                          The more facets that the sliced object has the smoother the edges of the slices...
                            Guanjin
                            Could you post your Chinese lingvo file [zipped] for other fellow users to benefit from - it's only fair - the rest of the tool is freely shared... 😕
                              Here's v5.12 http://forums.sketchucation.com/viewtopic.php?p=374969#p374969
                              Extra traps added for 'non-instances' within slice-collections [e.g. when slotting after editing].
                              Code CONSTANTS added for optional menu-location/single-submenu.
                              The lingvo files are now all UFT-8 encoded, to avoid problems when copying.
                              Typos in the FR lingvo file corrected, the correct PT Portuguese lingvo is now included.
                              • guanjinG
                                guanjin
                                Yes, I posted on there?
                                • B
                                  Bertier
                                  massively awesome !
                                    Thanks to Guanjin here's the Chinese lingvo file.
                                    Unzip it and put it into the TIG-Slicer subfolder in the Plugins folder...TIG-SlicerZH-CN-lingvo.zip
                                    It will be included in the zipped package, with future updates too...
                                      Here's v5.13 http://forums.sketchucation.com/viewtopic.php?p=374969#p374969
                                      The latest Chinese lingvo file is now included in the set.
                                      The RZ solutions have been improved: now less prone to error with complex shapes made when the ORIGIN is within the bounding-box of the sliced-object: useful when making horizontal Z[blue] slotted-ribs with R[amber] radially arranged slotted-spars in the vertical [rotate the slice-object onto its 'nose', if you want to transpose the rib/spar arrangements]...s5-13.PNG
                                      • utilerU
                                        utiler
                                        TIG, this is not a plugin that I would use often but it is soooo neat I can't help playing with it!!!
                                        Cheers!! 👍
                                        Just Curious...
                                        • guanjinG
                                          guanjin
                                          The RZ solutions have been improved: now less prone to error with complex shapes made when the ORIGIN is within the bounding-box of the sliced-object: useful when making horizontal Z[blue] slotted-ribs with R[amber] radially arranged slotted-spars in the vertical [rotate the slice-object onto its 'nose', if you want to transpose the rib/spar arrangements]...[attachment=0:spns2k8l]<!-- ia0 -->s5-13.PNG<!-- ia0 -->[/attachment:spns2k8l]
                                          TIG: very kind of you! Update so fast! 👍 👍 👍
                                          • gillesG
                                            gilles
                                            XXXXX?
                                            Thank you Sir.
                                            • 16
                                            • 17
                                            • 5 / 17
