    Do This Right Now!!!
    24 Posts 18 Posters 2.7k Views 18 Watching
    • KrisidiousK
      Krisidious
      as soon as you read this... go and backup all your models and your client files.
      I over wrote my entire work harddrive while trying to clone and copy my OS harddrive. so I've lost the last ten years of work... every sketchup model I've ever built is now gone.
      I've been using some various recovery programs and have found some of my models but they all say "this does not appear to be a sketchup model" when I try to open them.
      sooo... as soon as you read this... go and backup all your models and your client files.
      don't be dumb like me and lose your life's work.
      By: Kristoff Rand
      • boofredlayB
        boofredlay
        BIG SUCK.
        I backed all my stuff up last week.
        • soloS
          solo
          Tip of the day:
          I use an external hard drive to move all completed projects to, be it the SU model, materials, render setup, completed images etc all stored in a folder named after the project.
          http://www.solos-art.com
          • KrisidiousK
            Krisidious
            I've uploaded one of my houses that has been recovered... perhaps one of you can get it to open. who knows.
            http://www.aboveallhouseplans.com/Clients/Torre_III_Lindsey.zip
            By: Kristoff Rand
            • pbacotP
              I'm really sorry, Kris. Hope it actually turns out to be recoverable.
              So if we're speaking of Backups. I've become reliant on Apple TimeMachine. I hope it works in the end. (I do have some drives of old archives that need sorting though, TimeMachine is only everything on my main machine going back a year.)
              • N
                numerobis
                i'm sorry to hear this!
                I don't know, what software you are using to recover the data, but normally it should be possible to recover everything if it is "only" formatted and not overwritten with new data.
                I had good experiences with GetDataBack
                http://www.runtime.org/data-recovery-software.htm
                Good luck!
                And yes, you're right: backup, backup, backup!!!
                Last year one of my external HDDs (1TB!) died because off a corrupted usb-chip (btw. stay away from the newer Western Digital external 2,5" HDDs! They have no SATA interface anymore, but an usb connector directly soldered on the board and the data stream is encrypted - no chance to plug it on a SATA cable if the usb chip fails!!!) After this experience i'm now copying ALL my data on my server with data HDD in RAID1 (mirrored) and i have two seperated external backups from this partition, one of them stored in another house! πŸ˜‰
                • TIGT
                  I have a separate hard-drive that I auto-backup to regularly.
                  In case that fries or gets nicked I also backup manually to several different www locations/vaults/archives [my zumodrive is automatic but has not much space].
                  I too once lost a hard-drive - completely gone - so I too know the pain - but at least my pain was having to restore almost everything from backups - lost about a week's work in the end, and the time needed to fix everything back as it was.
                  I strongly suggest that you leave your hard-drive alone - everything you do with it will potentially overwrite something you might want.
                  Get it to someone who knows how to recover data - they might be able to get at least something back...
                  • daleD
                    dale
                    Have you tried to locate the files .skb file?
                    I believe this is the backup file created by SketchUp, and is not normally intended to be opened, (but this ain't normally)
                    I remember reading something about this a while back, so may be worth some research.
                    I tried to open your file using all the usual tricks, (renaming, dragging into skp icon, open from within application etc) but sorry no luck.
                    • TIGT
                      The SKP is missing the correct header - I tried adding one manually, but it's foobar... Google can sometime recover bad SKPs - try them...
                      • BepB
                        Bep
                        Maybe http://www.piriform.com/recuva can help.
                        I have tried Doublecad and various converters to get your file to open/transform, but no luck untill now. 😒
                        good luck!
                        Bep
                        "History is written by the winners"
                        • Bob JamesB
                          Bob James
                          Oh, this hurts my heart 😲 😞
                          I've lost some things over the years, but not everything.
                          I truly hope you're able to recover most or all of your work.
                          I'm paranoid about backup: I have a 5-disk raid on my machine, auto-back-up data to a 4-disk Drobo and backup to Carbonite.
                          • andybotA
                            andybot
                            Oh, that hurts! My sympathies. Also, another advice is to do optical backups regularly too. DVD's can't be overwritten (as long as you close it.)
                            • S
                              sonder
                              Really sorry to hear this. This happened to me many years ago. Since then I do daily back-ups. I now keep my work current on 2 separate working computers, a portable hard drive and a network drive. The network drives are awesome. I have a buffalo twin single terabyte network drive. It automatically backs up work as well as duplicates it on the second drive should either drive fail. It was probably the best $250 I have ever spent.
                              Keep your chin up. The one thing you haven't lost is the knowledge to create new work.
                              • D
                                dtrarch
                                Kris
                                What a shame but all may not be lost.
                                I use File Scavenger 3.0
                                Old app but will dig out the files as long as the drive works.
                                More than once I have said yes to the delete and kill key 😒
                                http://file-scavenger.en.softonic.com/
                                My version was about $50 US and worth every penny.
                                It will recover a whole drive but must copy to another backup drive.
                                Also as I recall it will also copy selected folders to a different folder on the same drive.
                                Do take look at the link info.
                                It really works.
                                Really sorry for you
                                dtr
                                • KrisidiousK
                                  Krisidious
                                  Thanks for all the kind words... I've run several recovery programs and have been able to find the files I lost however all are corrupt. so now I'm going to mail off the hard-drive to professional. I'll be using this company unless one of you knows of a better company or sees some reason why I shouldn't.
                                  http://www.salvagedata.com/
                                  They say I mail it to them and then they diagnose and evaluate the drive and what it will take to get the info out. cost is between $500 and $1100... no data no cost they say. and an estimate before any work starts. so sounds good to me. and they're #1 on Google for the term "data recovery" no easy feat in itself. so fingers crossed.
                                  Again, I appreciate the comforting and the advice. I'm quite embarrassed, I should know better. but I thought this might stand as a lesson to others... So at least there might be some benefit from my loss.
                                  I'll keep the thread updated to the progress.
                                  By: Kristoff Rand
                                  • Mike LuceyM
                                    Mike Lucey
                                    Kris, just a thought! Are you going to make a copy of the drive before sending or is this even possible?
                                    • KrisidiousK
                                      Krisidious
                                      I was thinking about that... but I don't think it would do much good as the important files are down below and I would think not copy-able. but I would be interested in hear as I have the cloning software and I have an extra identical sized drive.
                                      By: Kristoff Rand
                                      • KrisidiousK
                                        Krisidious
                                        I learned today that all I have to show for the last 14 years of work is what's in my head... Data Recovery Specialist says... "Files Unrecoverable." Heart Break to Ensue...
                                        Unfortunately due to the extent of physical/logical damage found on the media, this case has been deemed not recoverable. An email detailing specific findings to follow.
                                        Regards,
                                        The SalvageData Team
                                        By: Kristoff Rand
                                        • V
                                          valerostudio
                                          http://www.carbonite.com/en/ $59 a year and it's unlimited. It takes a long time to backup the first copy, but at least you are protected against disasters as well.
                                          • pbacotP
                                            Really sorry Kris. You still have our undying respect but I guess that's not quite enough at present... And you have the legacy of the projects that were built.
                                            • 1 / 2
