    Best (free) way to import DWG to SU 8 Free?
    9 Posts 5 Posters 47.5k Views 5 Watching
    • Z Offline
      Zoom123
      Hello,
      On my previous computer I had both Sketchup 7.1 Free and Sketchup 8 Free and I used SU 7.1 to import DWG files.
      Is there a better (and still free) way to do this that would not require the installation of 2 SU programs?
      Thanks!
      • numbthumbN Offline
        numbthumb
        If you can save your DWG as a DXF, you can use a DXF import plugin with the free version of SU:
        http://forums.sketchucation.com/viewtopic.php?f=323&t=31186
        Comfortably numb...
        • simon le bonS Offline
          simon le bon
          The plugin well cited by NumbThumb is from our regretted honoluludesktop:
          Here is a post from Jim Foltz into the thread which links to a free dwg/dxf converter : [Plugin] Dxf_In v1.2
          -->>Teigha® File Converter
          Please notice that Jim is also the author of the same idea plugin: [Plugin] FreeDXF Importer 2011-12-21
          I don't know the differences between them.
          ++simon
          • Z Offline
            Zoom123
            I am currently using DWG Viewer to view the plans send to me, I don't create the plans myself. I don't think DWG Viewer would allow me to save as DXF (since it is just a viewer).
            Is there any other free and easy to use application that would allow me to view the DWG files and also save as DXF?
            And when importing DXF using the plug-in, is the result the same as when importing DWG directly in Sketchup? (scale, layers preserved etc)
            • BepB Offline
              Bep
              Take a look at http://www.doublecad.com/Products/DoubleCADXTv3/tabid/1100/Default.aspx
              Bep
              "History is written by the winners"
              • Z Offline
                Zoom123
                Thanks, but I think that might be a bit too complicated for me. I am not really a CAD user. I just tried AutoCAD WS and it seems to give you the option to save as DFX. Anybody tried that?
                • andybotA Offline
                  andybot
                  As mentioned above, The Tiegha file viewer is a good solution - it's just a viewer that allows you to save DWG files in different formats. Don't need to learn anything to use it.
                  • Z Offline
                    Zoom123
                    I got the Teigha File Converter and it worked OK, but the DXF import plugin I tried (the first one listed) didn't work well with the files I had (it was slow and gave many errors)
                    I think I will just install both versions of SU (7 & 😎 and continue working as I did so far.
                    • andybotA Offline
                      andybot
                      Good to know. I use the SU7 import typically, hadn't tried the dxf importer. I guess I will stick to that for now too.
