    Lost Outliner/Component/Material Window Offscreen
    7 Posts 6 Posters 9.9k Views 6 Watching
    • KrisidiousK
      Krisidious
      Lost Outliner/Component/Material Window Offscreen?
      Ever have an issue when you're using multiple monitors and you lose one or more of your toolbar windows offscreen?
      here's a quick solution...
      1.open the entity window or any other window you can get to inside of sketchup.
      2.right click on the top of that window as you would a program in windows.
      3.select move.
      as you hit move the "lost" window will snap to the window your clicking on and will be under it.
      this should help if you ever lose any of the windows within sketchup.
      By: Kristoff Rand
      • Wo3DanW
        Wo3Dan
        @krisidious said:
        Lost Outliner/Component/Material Window Offscreen?....
        ...as you hit move the "lost" window will snap to the window your clicking on and will be under it.....
        I just had to try this.
        So I managed to get 'Outliner' off screen, hoping and expecting that you are right! 😕
        I started fishing with the 'Layers' window and there it was again, nicely hooked underneath. 😎
        Great tip. 💭
        Thanks!
        • G
          glro
          3.select move.
          great tip!!
          it worked for me also
          thank you 😄
          • KrisidiousK
            Krisidious
            My pleasure... Drove me nuts.
            By: Kristoff Rand
            • M
              MPMabres
              Sorry, it didn´t work for me.
              My problem is when I want to make a component. I right click on the object and select Make component from the menu. Then the dialog is gone off the screen and I can´t get it back.
              Is there anybody that can help?
                What didn't work for you? Did you try Box's fix?
                Have you tried Preferences>Workspace>Reset Workspace?
                Are you still using SketchUp 2017 Make as indicated in your profile or have you upgraded?
                • BoxB
                  There's also the other way, Go Window/Outliner (or whichever dialog you want to put the focus on) then hit alt and space then m then any arrow key and move the mouse around until the dialog comes into view.
