    Problems achieve face along arcs
    8 Posts 5 Posters 558 Views 5 Watching
    • U Offline
      unmeilleurreve
      Alright, so I'm definitely new around here, and I've been having trouble with a specific problem. I have 3 arcs, concentric to the y axis. The leftmost point of the arc starts at 2.5mm intervals, the rightmost at 7.5mm intervals, and the radius ascends a similar column of guide points at 5 mm intervals. I allowed sketchup to simply use 12 segments for each arc. What I need is for these to develop faces when I connect the endpoints with lines so that I can make the front section for a ring. I've tried Fullmer's bending plugin with a different pattern to achieve similar results to no avail. It seems that, regardless of what I do, sketchup refuses to make the corresponding object solid. I'm attaching the sketchup file.
      And in case I wasn't able to convey myself clearly, the area that I need to make the face occur along the curves, not inside of the arc.
      model
      • TIGT Online
        • U Offline
          unmeilleurreve
          That is very, very close. However, I'm looking to have the lines preserved. I really think I'm going about this the wrong way.....
          I'm looking to eventually impose this on a ring shape, you see, and chamfer along the lines.... But I'm definitely going about it the wrong way, because ideally the chamfer tapers. Gah! Additionally, the lines need to push outward a total of 1mm. πŸ˜•
          • U Offline
            unmeilleurreve
            Here's a better explanation, and I managed to do it all manually with a decent number of rough edges...
            • TIGT Online
              In my example the original curved lines ARE preserved.
              I simply moved the grouped mesh away from them for clarity.
              The usual last option dialog in EEby... tools - 'Erase Original Curves ?' - the choice is yours...
              Exploding the smoothed mesh will then recombine it with those curved lines...
              πŸ˜•
              • irwanwrI Offline
                irwanwr
                edit:
                what explanation?
                • Jean LemireJ Offline
                  Jean Lemire
                  Hi folks.
                  See this SU file for ideas.
                  I created the model at a 100x scale since SU has some difficulties with very small geometries.
                  The last step would be to scale down the model by a factor of 0.01.
                  Just ideas.
                  Wedged arc.skp
                  • dukejazzD Offline
                    dukejazz
                    1. I uploaded you skp file an open it
                    2. Took line tool closed the 4 areas
                    3. check dimension
                    4. resized top 3 areas
                    5. pushpulled the botttom one
                    6. Context Intersect with selection
                    7. Trim and remeasured
                    8. Tested the volume and smoothed the edges
                    9. Tranpanency mode
                    My error was inside material need deleted before runing the test
                    If makring a ring skin then
                    10) After push-pull smooth the pull volume
                    11) Context Intersect with selection
                    12) Make group then explode, use the erase on back edges
                    13) Done
                    I hope this may help?
