    White spots on bump map with reflection layer
    renderpluginsextensions
    6 Posts 3 Posters 1.2k Views 3 Watching
    • peter_shawP Offline
      peter_shaw
      Before i run 10h of testing what could be the problem, maybe someone here knows the solution to this.
      i created a ceramic roofing material myself:
      photoshop->converted to BW with red filter
      and used the BM as reflection map on the reflection and highlight slot.
      i tested how it looks and it was fine:
      only bumpmap, texfresel IOR 2
      when i added the reflection map i noticed the white spots in the upper part, strange:
      bump+reflection maps, texfresnel 2.0
      and when i rendered a planar roof, this happened:
      notice the white pixels on the roof, you have to zoom in
      material settiongs:
      settings
      so... is it a problem with the bump map, which i used for the reflection slots as well? or is it something completey different?
      or maybe there is a completely different approach in rendering roof textures? i just dont want to use displacment.
      • andybotA Offline
        andybot
        occasionally I run into an issue with maps where something that is 255 white or 0 black will do odd things - particularly in displacement maps. Try editing your bump map with curves so you don't have pure white or pure black. Perhaps that might help.
        Andy
          dsarchs
          I can't help you with VRay, but that's a VERY reflective/shiny roof. Clay tiles would have a much more diffuse, almost imperceptible reflection.
          Knowledge is a polite word for dead but not buried imagination.
          -e.e.cummings
          • andybotA Offline
            andybot
            not if you shellac them πŸ˜†
            Serious though, that's a good point. I would suggest decreasing your reflective glossiness (and the Hilight option too) to something like 0.65 (and increase the reflective subdivisions to 16)
              peter_shaw
              thanks andybot, gonna try to edit the BM first thing on monday.
              of course the glossiness is too much, but not by that far. there are glazed roof tiles that kinda look like that.
              http://www.roeben.com/de/roben-international/produkte/dachziegel/glasierte-dachziegel/6_66.html
              http://www.dachdeckerei-grafe.de/beispiele_ziegel_glasur_braun.htm
              http://www.roeben.com/media/35_flandernplus_barolo_glasur.jpg
              maybe its a german thing πŸ˜„
              what is the effect of subdivions on reflections?
              • andybotA Offline
                andybot
                interesting, those are glazed then. I am more familiar with the unglazed type. You might want to add a second reflection layer to give a deeper reflection. If you look at some of the car paint vismats (available in the download section at the chaosgroup site) those use a combination of reflection layers to give depth to the reflection. I couldn't tell you offhand which ones to look at.
                The increased subdivisions gives a cleaner rendering. With low subdivisions, the result is sometimes noisy.
