    I invite for acquaintance with Russian plug-in
    77 Posts 18 Posters 26.4k Views 18 Watching
      tony bombata
      @jorge2011 said:
      I receive the following error code after installing.
      Thanks you in advance for your help.
      Ken
      You must copy the file "iconv.so" in the folder:
      windows/system32
      i use x64 windows and i had the same problem
      copied iconv.so and iconv.dll to win2, wow64, sketchup plugins and coolpipe folders
      don't know which worked out but it's working
      • Dan RathbunD Offline
        Dan Rathbun
        Well which one of those paths are in the $LOAD_PATH array ??
        I'm not here much anymore.
        • guanjinG Offline
          guanjin
          @yad2000 said:
          Please bring a list of documents for which you want to add elements. Now used only 2 Russian document on the piping. If you write a number of documents that you use and you can download them somewhere, I'll add them to the database to avoid similar mistakes.
          I can not open the page, to download, why not posted on the website
          I come from China, is to learn
          • yad2000Y Offline
            yad2000
            Coolpipe.ru site - located in the ucoz.com - if none of the sites of ucoz you can not read - then the problem is with your provider.
            CoolPipe Plugin
            • guanjinG Offline
              guanjin
              @yad2000 said:
              @irwanwr said:
              if the plugin will be available in English version and shared here too.
              if it is true.
              this is true, but it will probably not soon. Will take some time to create a fully functional version of the native language, only then do the translation. It is possible I will ask for help - if you do not mind
              Finally downloaded, loaded error
              • yad2000Y Offline
                yad2000
                @guanjin said:
                @yad2000 said:
                if it is true.
                [attachment=0:15v5ur39]<!-- ia0 -->未命名.jpg<!-- ia0 -->[/attachment:15v5ur39]
                in the file that you changed - Error!
                you must:
                "沿线 管道 目录 列表,
                replaced by
                "沿线 管道 目录 列表",
                should work
                CoolPipe Plugin
                • guanjinG Offline
                  guanjin
                  Successfully translated into Chinese, but has not been used successfully, the of plumbing tools?
                  • yad2000Y Offline
                    yad2000
                    Normative documents only Russian. To broaden the base of the elements - I need to know what documents you use. They are very much, all I add one can not afford
                    CoolPipe Plugin
                    • guanjinG Offline
                      guanjin
                      I do not know that you mean ,the file is a common indoor plumbing components
                      • yad2000Y Offline
                        yad2000
                        I also do not understand what you want)))
                        CoolPipe Plugin
                        • yad2000Y Offline
                          yad2000
                          I will say this: I have now developed a new version of the plugin, which will not appear on [iconv] and [web dialogues]. The most interesting thing to come, as the plugin will look - still a secret. When will the release of do not know. Work to be very much as I want to do everything in Ruby without any HTML and JavaScript
                          CoolPipe Plugin
                          • yad2000Y Offline
                            yad2000
                            who knows how to use the database MongoDB in Ruby for SketchUP ❓
                            here...
                            CoolPipe Plugin
                            • yad2000Y Offline
                              yad2000
                              Time is now developing a new interface for plug-in.
                              Here is a screenshot
                              I want to abandon HTML, JavaScript, CSV. I am looking for ways to solve problems with the database.
                              Who share the standards DIN / EN / ISO / API / ASTM / ASME?
                              CoolPipe Plugin
                              • yad2000Y Offline
                                yad2000
                                Who shares the standards DIN / EN / ISO / API / ASTM / ASME?
                                For further development of the plugin. Interest standards for all items, not just on the tube. At least to start with 2 pcs. You can share the standard is not complete, but only the image and style options.
                                Google Translator gives terrible translations)))
                                In Russia, the translation is: "Your - my not understand"))))
                                CoolPipe Plugin
                                • kenK Offline
                                  ken
                                  Hello
                                  I have tried and tried to get this program to work. I keep getting the attached error. I have the file, iconv.so in the correct directory as shown.
                                  So what is wrong, and can it be fixed? I deal with pipes diagrams and would like for this to work.
                                  So thanks in advance for your help.
                                  Ken
                                    driven
                                    Hello
                                    Ken
                                    Start.rb is not finding iconv.so is what your message says, and it needs it so it reports an error....
                                    I'm on mac, but it looks like you need to put the missing file into your plugins folder >>> iconv.so
                                    john
                                    • FrederikF Offline
                                      Frederik
                                      Looks like a very interesting plugin... 👍
                                      Unfortunately I seem to share the same issue as Ken...
                                      I've never had any issue installing a plugin - before now... 😕
                                      I even tried to copy the iconv.so to the plugins folder, but to no avail... 😐
                                      Cheers
                                      Kim Frederik
                                      • FrederikF Offline
                                        Frederik
                                        OK... Tried to see if I could see something in the coolpipe_Start.rb
                                        (yep - it's dangerous when having a very limited knowledge when it comes to coding... 😆 )
                                        The original code looked like this:
                                        #encoding; utf-8
                                        # Cool Pipe Engine 2011-2012
                                        # Cool Pipe Engine 2011-2012 to the SketchUp interface
                                        # version 1.2
                                        # Software Author;     Borisov Denis Vladimirovich (yad2000@rambler.ru)
                                        # Design;              Borisov Denis Vladimirovich (yad2000@rambler.ru)
                                        # ©2012 by Borisov Denis Vladimirovich (yad2000@rambler.ru)
                                        #История версий
                                        #-v1.2.1
                                        #-Мультиязычность проекта (русский,английский,французский,итальянский,испанский,немецкий), возможность выбора языка в процессе работы с плагином
                                        #-Расчет массы отвода (стального), расчитыватеся по геометрическим параметрам (может не соответствовать с заводским изделиям)
                                        #-Структура кода измененена; отсутствует изменение стандартных классов, весь код объединен в классы и модули
                                        #-внесено исправление по загрузке iconv.so; на MAC не загружать, только на Windows
                                        #-редактирование элементов вынесено за пределы Observer при выделении на отдельную командную кнопку
                                        #-исправлен принцип сортировки элементов спецификации на стандартный .sort (для избежания утечки памяти в процессе подсчета и зависаний SketchUP)
                                        #-v1.2
                                        #-Изменение структуры работы с базой данных элементов
                                        #-Рисование и редактирование трубопроводов
                                        #-Рисование и редактирование отводов
                                        #-Рисование и редактирование переходов
                                        #-Рисование и редактирование тройников
                                        #-Рисование заглушек
                                        #-Рисование фланцев
                                        #-Создание спецификации
                                        #-Функция копирования свойств (слой+материал) для объектов CoolPipe и групп
                                        #v1.1
                                        #-Следующие публикации по адресу; http://coolpipe.ru/load
                                        #-Кардинально изменен дизайн диалога с пользователем
                                        #-Дополнена база ГОСТов трубопроводов
                                        #-Рисование трубопроводов мышью
                                        #-Накладывание слоев, собственный редактор "быстрых" слоев
                                        #-Накладывание материалов (боевая раскраска трубопроводов)
                                        #-Накладывание теплоизоляции + редактор стандартных толщин изоляции
                                        #-Функция "Прилепить отвод"
                                        #-Функции редактирования трубопроводов (задание уклона или отметок трубопровода)
                                        #-Функции редактирования отводов при выделении самих отводов мышью (экранное меню)
                                        #-Функция "Составление спецификации"
                                        #--разработка прервана
                                        #v1.0
                                        #Пробный плагин (в виде тулбара) рисующий трубы, отводы, переходы, тройники, заглушки, фланцы по известным ГОСТам
                                        #Первая публикация по адресу; http://forum.abok.ru/index.php?&showtopic=30806&st=160
                                        require 'sketchup.rb'
                                        require 'CoolPipe/cp_Lang.rb'
                                        require 'CoolPipe/Service_proc.rb'
                                        require 'CoolPipe/PipeTool.rb'
                                        require 'CoolPipe/ElbowTool.rb'
                                        require 'CoolPipe/ReducerTool.rb'
                                        require 'CoolPipe/TeeTool.rb'
                                        require 'CoolPipe/CapTool.rb'
                                        require 'CoolPipe/FlangeTool.rb'
                                        require 'CoolPipe/cpCSVBase.rb'
                                        require 'CoolPipe/CopyOptionsTool.rb'
                                        pform = (Object;;RUBY_PLATFORM =~ /mswin/i) ? ;windows ; ((Object;;RUBY_PLATFORM =~ /darwin/i) ? ;mac ; ;other)
                                        platform = pform.to_s
                                        if platform == "windows"
                                          require 'CoolPipe/iconv.so' #  применяем iconv
                                        elsif platform == "mac"
                                           #  не применяем
                                        CoolPipe_number_version = "1.2.1" # Текущая версия плагина
                                        coolpipe_plugin = CoolPipePluginApp.new
                                        coolpipe_plugin.run
                                        So I deleted the two spaces in line 62 in front of "require"
                                        Now I get this Load Error message:
                                        Cheers
                                        Kim Frederik
                                        • yorik1984Y Offline
                                          yorik1984
                                          Copy iconv.co to C:\Windows\system32
                                            Dan Rathbun
                                            @yorik1984 said:
                                            Copy iconv.so to C:\Windows\system32
                                            NO.. DO NOT !
                                            It does not belong in the OS system directory !
                                            • 3 / 4
