    I invite for acquaintance with Russian plug-in
    77 Posts 18 Posters 26.4k Views 18 Watching
    • yad2000Y Offline
      yad2000
      @guanjin said:
      @yad2000 said:
      @irwanwr said:
      if the plugin will be available in English version and shared here too.
      if it is true.
      this is true, but it will probably not soon. Will take some time to create a fully functional version of the native language, only then do the translation. It is possible I will ask for help - if you do not mind
      [attachment=0:15v5ur39]<!-- ia0 -->未命名.jpg<!-- ia0 -->[/attachment:15v5ur39]
      Finally downloaded, loaded error
      in the file that you changed - Error!
      you must:
      "沿线 管道 目录 列表,
      replaced by
      "沿线 管道 目录 列表",
      should work
      CoolPipe Plugin
      • guanjinG Offline
        guanjin
        Successfully translated into Chinese, but has not been used successfully, the of plumbing tools?
        • yad2000Y Offline
          yad2000
          Normative documents only Russian. To broaden the base of the elements - I need to know what documents you use. They are very much, all I add one can not afford
          CoolPipe Plugin
          • guanjinG Offline
            guanjin
            I do not know that you mean ,the file is a common indoor plumbing components
            • yad2000Y Offline
              yad2000
              I also do not understand what you want)))
              CoolPipe Plugin
              • yad2000Y Offline
                yad2000
                I will say this: I have now developed a new version of the plugin, which will not appear on [iconv] and [web dialogues]. The most interesting thing to come, as the plugin will look - still a secret. When will the release of do not know. Work to be very much as I want to do everything in Ruby without any HTML and JavaScript
                CoolPipe Plugin
                • yad2000Y Offline
                  yad2000
                  who knows how to use the database MongoDB in Ruby for SketchUP ❓
                  here...
                  CoolPipe Plugin
                  • yad2000Y Offline
                    yad2000
                    Time is now developing a new interface for plug-in.
                    Here is a screenshot
                    I want to abandon HTML, JavaScript, CSV. I am looking for ways to solve problems with the database.
                    Who share the standards DIN / EN / ISO / API / ASTM / ASME?
                    CoolPipe Plugin
                    • yad2000Y Offline
                      yad2000
                      Who shares the standards DIN / EN / ISO / API / ASTM / ASME?
                      For further development of the plugin. Interest standards for all items, not just on the tube. At least to start with 2 pcs. You can share the standard is not complete, but only the image and style options.
                      Google Translator gives terrible translations)))
                      In Russia, the translation is: "Your - my not understand"))))
                      CoolPipe Plugin
                      • kenK Offline
                        ken
                        Hello
                        I have tried and tried to get this program to work. I keep getting the attached error. I have the file, iconv.so in the correct directory as shown.
                        So what is wrong, and can it be fixed? I deal with pipes diagrams and would like for this to work.
                        So thanks in advance for your help.
                        Ken
                          driven
                          Hello
                          Ken
                          Start.rb is not finding iconv.so is what your message says, and it needs it so it reports an error....
                          I'm on mac, but it looks like you need to put the missing file into your plugins folder >>> iconv.so
                          • FrederikF Offline
                            Frederik
                            Looks like a very interesting plugin... 👍
                            Unfortunately I seem to share the same issue as Ken...
                            I've never had any issue installing a plugin - before now... 😕
                            I even tried to copy the iconv.so to the plugins folder, but to no avail... 😐
                            Cheers
                            Kim Frederik
                            • FrederikF Offline
                              Frederik
                              OK... Tried to see if I could see something in the coolpipe_Start.rb
                              (yep - it's dangerous when having a very limited knowledge when it comes to coding... 😆 )
                              The original code looked like this:
                              #encoding; utf-8
                              # Cool Pipe Engine 2011-2012
                              # Cool Pipe Engine 2011-2012 to the SketchUp interface
                              # version 1.2
                              # Software Author;     Borisov Denis Vladimirovich (yad2000@rambler.ru)
                              # Design;              Borisov Denis Vladimirovich (yad2000@rambler.ru)
                              # ©2012 by Borisov Denis Vladimirovich (yad2000@rambler.ru)
                              #История версий
                              #-v1.2.1
                              #-Мультиязычность проекта (русский,английский,французский,итальянский,испанский,немецкий), возможность выбора языка в процессе работы с плагином
                              #-Расчет массы отвода (стального), расчитыватеся по геометрическим параметрам (может не соответствовать с заводским изделиям)
                              #-Структура кода измененена; отсутствует изменение стандартных классов, весь код объединен в классы и модули
                              #-внесено исправление по загрузке iconv.so; на MAC не загружать, только на Windows
                              #-редактирование элементов вынесено за пределы Observer при выделении на отдельную командную кнопку
                              #-исправлен принцип сортировки элементов спецификации на стандартный .sort (для избежания утечки памяти в процессе подсчета и зависаний SketchUP)
                              #-v1.2
                              #-Изменение структуры работы с базой данных элементов
                              #-Рисование и редактирование трубопроводов
                              #-Рисование и редактирование отводов
                              #-Рисование и редактирование переходов
                              #-Рисование и редактирование тройников
                              #-Рисование заглушек
                              #-Рисование фланцев
                              #-Создание спецификации
                              #-Функция копирования свойств (слой+материал) для объектов CoolPipe и групп
                              #v1.1
                              #-Следующие публикации по адресу; http://coolpipe.ru/load
                              #-Кардинально изменен дизайн диалога с пользователем
                              #-Дополнена база ГОСТов трубопроводов
                              #-Рисование трубопроводов мышью
                              #-Накладывание слоев, собственный редактор "быстрых" слоев
                              #-Накладывание материалов (боевая раскраска трубопроводов)
                              #-Накладывание теплоизоляции + редактор стандартных толщин изоляции
                              #-Функция "Прилепить отвод"
                              #-Функции редактирования трубопроводов (задание уклона или отметок трубопровода)
                              #-Функции редактирования отводов при выделении самих отводов мышью (экранное меню)
                              #-Функция "Составление спецификации"
                              #--разработка прервана
                              #v1.0
                              #Пробный плагин (в виде тулбара) рисующий трубы, отводы, переходы, тройники, заглушки, фланцы по известным ГОСТам
                              #Первая публикация по адресу; http://forum.abok.ru/index.php?&showtopic=30806&st=160
                              require 'sketchup.rb'
                              require 'CoolPipe/cp_Lang.rb'
                              require 'CoolPipe/Service_proc.rb'
                              require 'CoolPipe/PipeTool.rb'
                              require 'CoolPipe/ElbowTool.rb'
                              require 'CoolPipe/ReducerTool.rb'
                              require 'CoolPipe/TeeTool.rb'
                              require 'CoolPipe/CapTool.rb'
                              require 'CoolPipe/FlangeTool.rb'
                              require 'CoolPipe/cpCSVBase.rb'
                              require 'CoolPipe/CopyOptionsTool.rb'
                              pform = (Object;;RUBY_PLATFORM =~ /mswin/i) ? ;windows ; ((Object;;RUBY_PLATFORM =~ /darwin/i) ? ;mac ; ;other)
                              platform = pform.to_s
                              if platform == "windows"
                                require 'CoolPipe/iconv.so' #  применяем iconv
                              elsif platform == "mac"
                                 #  не применяем
                              CoolPipe_number_version = "1.2.1" # Текущая версия плагина
                              coolpipe_plugin = CoolPipePluginApp.new
                              coolpipe_plugin.run
                              So I deleted the two spaces in line 62 in front of "require"
                              Now I get this Load Error message:
                              Cheers
                              Kim Frederik
                              • yorik1984Y Offline
                                yorik1984
                                Copy iconv.co to C:\Windows\system32
                                • Dan RathbunD Offline
                                  Dan Rathbun
                                  @yorik1984 said:
                                  Copy iconv.so to C:\Windows\system32
                                  NO.. DO NOT !
                                  It does not belong in the OS system directory !
                                  I'm not here much anymore.
                                    yorik1984
                                       #  не применяем
                                    Frederik has WINDOWS!
                                      driven
                                      and Dan is saying "DON'T" move the file into the C:\Windows\system32 system path, it won't be found and doesn't belong there...
                                      @ Fredrick if you suspect the require is not working test it in 'Ruby Console'. e.g.
                                      should return windows
                                      then try
                                         #  не применяем
                                      should return true
                                      if it does it's not the problem, if it doesn't, check permissions on that file... 'CoolPipe/iconv.so' in that Directory, don't move it...
                                      • FrederikF Offline
                                        Frederik
                                        Thanks for the heads up...
                                        Much appreciated... 👍
                                        I don't dare to copy any files into the C:\Windows\System32 folder...
                                        It seem strange that I would need to copy a file to a OS system folder... 😐
                                        From the videos this plugin looks very interesting...
                                        I'm working as Project Manager and my job is to make 2D and 3D drawings, mechanical design, building design, surface calculation, volume calculation, walk through in buildings, equipment layout in control/engineering rooms, piping design, piping and equipment support design, of the cooling systems we're going to be working on...
                                        On a daily basis I'm using the 3skeng plugin, which suits my needs well...
                                        Since this is also related to the piping industry I wanted to check it out, but as long as I can't get it to work, I will stick to the 3skeng plugin... 😉
                                        Cheers
                                        Kim Frederik
                                        • FrederikF Offline
                                          Frederik
                                          It sure does...
                                          @driven said:
                                          then try
                                          >    #  не применяем
                                          > end
                                          should return true
                                          A bit strange...
                                          It seem to only allow me to write
                                          I don't seem to be able to insert the remaining text... 😕
                                          Cheers
                                          Kim Frederik
                                            driven
                                            @frederik said:
                                            I don't seem to be able to insert the remaining text... :?
                                            I think that's the windows single line 'Ruby Console' thing... mac is multiline, and mines actually full page as well, sorry..
                                            just use the require and see if it returns true
                                            might need the rest of path if nothing else has loaded..
                                            • 3 / 4
