    I invite for acquaintance with Russian plug-in
    77 Posts 18 Posters 26.7k Views 18 Watching
    • yad2000Y Offline
      yad2000
      I also do not understand what you want)))
      CoolPipe Plugin
      • yad2000Y Offline
        yad2000
        I will say this: I have now developed a new version of the plugin, which will not appear on [iconv] and [web dialogues]. The most interesting thing to come, as the plugin will look - still a secret. When will the release of do not know. Work to be very much as I want to do everything in Ruby without any HTML and JavaScript
        CoolPipe Plugin
        • yad2000Y Offline
          yad2000
          who knows how to use the database MongoDB in Ruby for SketchUP ❓
          here...
          CoolPipe Plugin
          • yad2000Y Offline
            yad2000
            Time is now developing a new interface for plug-in.
            Here is a screenshot
            I want to abandon HTML, JavaScript, CSV. I am looking for ways to solve problems with the database.
            Who share the standards DIN / EN / ISO / API / ASTM / ASME?
            CoolPipe Plugin
            • yad2000Y Offline
              yad2000
              Who shares the standards DIN / EN / ISO / API / ASTM / ASME?
              For further development of the plugin. Interest standards for all items, not just on the tube. At least to start with 2 pcs. You can share the standard is not complete, but only the image and style options.
              Google Translator gives terrible translations)))
              In Russia, the translation is: "Your - my not understand"))))
              CoolPipe Plugin
              • kenK Offline
                ken
                Hello
                I have tried and tried to get this program to work. I keep getting the attached error. I have the file, iconv.so in the correct directory as shown.
                So what is wrong, and can it be fixed? I deal with pipes diagrams and would like for this to work.
                So thanks in advance for your help.
                Ken
                  driven
                  Hello
                  Ken
                  Start.rb is not finding iconv.so is what your message says, and it needs it so it reports an error....
                  I'm on mac, but it looks like you need to put the missing file into your plugins folder >>> iconv.so
                  • FrederikF Offline
                    Frederik
                    Looks like a very interesting plugin... 👍
                    Unfortunately I seem to share the same issue as Ken...
                    I've never had any issue installing a plugin - before now... 😕
                    I even tried to copy the iconv.so to the plugins folder, but to no avail... 😐
                    Cheers
                    Kim Frederik
                    • FrederikF Offline
                      Frederik
                      OK... Tried to see if I could see something in the coolpipe_Start.rb
                      (yep - it's dangerous when having a very limited knowledge when it comes to coding... 😆 )
                      The original code looked like this:
                      #encoding; utf-8
                      # Cool Pipe Engine 2011-2012
                      # Cool Pipe Engine 2011-2012 to the SketchUp interface
                      # version 1.2
                      # Software Author;     Borisov Denis Vladimirovich (yad2000@rambler.ru)
                      # Design;              Borisov Denis Vladimirovich (yad2000@rambler.ru)
                      # ©2012 by Borisov Denis Vladimirovich (yad2000@rambler.ru)
                      #История версий
                      #-v1.2.1
                      #-Мультиязычность проекта (русский,английский,французский,итальянский,испанский,немецкий), возможность выбора языка в процессе работы с плагином
                      #-Расчет массы отвода (стального), расчитыватеся по геометрическим параметрам (может не соответствовать с заводским изделиям)
                      #-Структура кода измененена; отсутствует изменение стандартных классов, весь код объединен в классы и модули
                      #-внесено исправление по загрузке iconv.so; на MAC не загружать, только на Windows
                      #-редактирование элементов вынесено за пределы Observer при выделении на отдельную командную кнопку
                      #-исправлен принцип сортировки элементов спецификации на стандартный .sort (для избежания утечки памяти в процессе подсчета и зависаний SketchUP)
                      #-v1.2
                      #-Изменение структуры работы с базой данных элементов
                      #-Рисование и редактирование трубопроводов
                      #-Рисование и редактирование отводов
                      #-Рисование и редактирование переходов
                      #-Рисование и редактирование тройников
                      #-Рисование заглушек
                      #-Рисование фланцев
                      #-Создание спецификации
                      #-Функция копирования свойств (слой+материал) для объектов CoolPipe и групп
                      #v1.1
                      #-Следующие публикации по адресу; http://coolpipe.ru/load
                      #-Кардинально изменен дизайн диалога с пользователем
                      #-Дополнена база ГОСТов трубопроводов
                      #-Рисование трубопроводов мышью
                      #-Накладывание слоев, собственный редактор "быстрых" слоев
                      #-Накладывание материалов (боевая раскраска трубопроводов)
                      #-Накладывание теплоизоляции + редактор стандартных толщин изоляции
                      #-Функция "Прилепить отвод"
                      #-Функции редактирования трубопроводов (задание уклона или отметок трубопровода)
                      #-Функции редактирования отводов при выделении самих отводов мышью (экранное меню)
                      #-Функция "Составление спецификации"
                      #--разработка прервана
                      #v1.0
                      #Пробный плагин (в виде тулбара) рисующий трубы, отводы, переходы, тройники, заглушки, фланцы по известным ГОСТам
                      #Первая публикация по адресу; http://forum.abok.ru/index.php?&showtopic=30806&st=160
                      require 'sketchup.rb'
                      require 'CoolPipe/cp_Lang.rb'
                      require 'CoolPipe/Service_proc.rb'
                      require 'CoolPipe/PipeTool.rb'
                      require 'CoolPipe/ElbowTool.rb'
                      require 'CoolPipe/ReducerTool.rb'
                      require 'CoolPipe/TeeTool.rb'
                      require 'CoolPipe/CapTool.rb'
                      require 'CoolPipe/FlangeTool.rb'
                      require 'CoolPipe/cpCSVBase.rb'
                      require 'CoolPipe/CopyOptionsTool.rb'
                      pform = (Object;;RUBY_PLATFORM =~ /mswin/i) ? ;windows ; ((Object;;RUBY_PLATFORM =~ /darwin/i) ? ;mac ; ;other)
                      platform = pform.to_s
                      if platform == "windows"
                        require 'CoolPipe/iconv.so' #  применяем iconv
                      elsif platform == "mac"
                         #  не применяем
                      CoolPipe_number_version = "1.2.1" # Текущая версия плагина
                      coolpipe_plugin = CoolPipePluginApp.new
                      coolpipe_plugin.run
                      So I deleted the two spaces in line 62 in front of "require"
                      Now I get this Load Error message:
                      Cheers
                      Kim Frederik
                      • yorik1984Y Offline
                        yorik1984
                        Copy iconv.co to C:\Windows\system32
                        • Dan RathbunD Offline
                          Dan Rathbun
                          @yorik1984 said:
                          Copy iconv.so to C:\Windows\system32
                          NO.. DO NOT !
                          It does not belong in the OS system directory !
                          I'm not here much anymore.
                            yorik1984
                               #  не применяем
                            Frederik has WINDOWS!
                              driven
                              and Dan is saying "DON'T" move the file into the C:\Windows\system32 system path, it won't be found and doesn't belong there...
                              @ Fredrick if you suspect the require is not working test it in 'Ruby Console'. e.g.
                              should return windows
                              then try
                                 #  не применяем
                              should return true
                              if it does it's not the problem, if it doesn't, check permissions on that file... 'CoolPipe/iconv.so' in that Directory, don't move it...
                              • FrederikF Offline
                                Frederik
                                Thanks for the heads up...
                                Much appreciated... 👍
                                I don't dare to copy any files into the C:\Windows\System32 folder...
                                It seem strange that I would need to copy a file to a OS system folder... 😐
                                From the videos this plugin looks very interesting...
                                I'm working as Project Manager and my job is to make 2D and 3D drawings, mechanical design, building design, surface calculation, volume calculation, walk through in buildings, equipment layout in control/engineering rooms, piping design, piping and equipment support design, of the cooling systems we're going to be working on...
                                On a daily basis I'm using the 3skeng plugin, which suits my needs well...
                                Since this is also related to the piping industry I wanted to check it out, but as long as I can't get it to work, I will stick to the 3skeng plugin... 😉
                                Cheers
                                Kim Frederik
                                • FrederikF Offline
                                  Frederik
                                  It sure does...
                                  @driven said:
                                  then try
                                  >    #  не применяем
                                  > end
                                  should return true
                                  A bit strange...
                                  It seem to only allow me to write
                                  I don't seem to be able to insert the remaining text... 😕
                                  Cheers
                                  Kim Frederik
                                    driven
                                    @frederik said:
                                    I don't seem to be able to insert the remaining text... :?
                                    I think that's the windows single line 'Ruby Console' thing... mac is multiline, and mines actually full page as well, sorry..
                                    just use the require and see if it returns true
                                    might need the rest of path if nothing else has loaded..
                                      driven
                                      I think single line looks like this
                                      if platform == "windows"; require 'CoolPipe/iconv.so'; elsif platform == "mac";  end
                                      but I never need it so... john
                                      • FrederikF Offline
                                        Frederik
                                        Cheers, John...!
                                        I believe I will just leave it as is for the time being...
                                        Like I wrote I don't like to copy anything to any system folder, so until they come up with an alternative plugin, I will stick to 3skeng... 😄
                                        Cheers
                                        Kim Frederik
                                        • kenK Offline
                                          ken
                                          I have tried each and every suggestion trying to get this plugin to work. The error is the same, can not find iconv.so.
                                          Is there anyone that has this plugin working on a Windows machine?
                                          And if you do have it working on a Windows machine, what size is your iconv.so. My iconv.so file is 24661 Date 2008-08-12-14:18.
                                          I can't believe it is so hard to get this plugin to work.
                                          Anyway thanks in advance. I am surprised the author doesn't offer any help.
                                          Ken
                                            driven
                                            @Ken & @Fredrick,
                                            I had a look on the russian forum the authors reply to your issue is
                                            Has already been written about it many times. Find the folder with the plugin file iconv.dll and throw it in the folder 😄 \ Windows \ System32 without this dll can not run so .... and no magic
                                            I don't know windows at all, but he is saying to move the iconv.dll not the iconv.so as suggested in this thread.
                                            I don't know if adding .dll is wise, maybe dan will comment...
                                            • 3 / 4
